Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-20-2006, 10:59 AM
PlayStation3 PlayStation3 is offline
spark plug wires
hi, i was wonderig has anybody tried these spark plug wire's before
http://store.summitracing.com/partde...6+4294864973+0
they are a little more but i don't mind the difference
Old 07-21-2006, 12:08 AM
Cat Fuzz Cat Fuzz is offline
Re: spark plug wires
Those look like a bunch of crap to me.
Nology HotWires ignition wire sets feature extremely technologically advanced wires that create an undeniably powerful spark.
Spark plug wires do not "create spark". Thats the job of the coil.
They're engineered with a special built-in capacitor, exclusive to HotWires. This allows energy from the ignition coil to accumulate in the capacitor until the voltage at the spark plug electrodes reaches the ionization point.
The spark is nearly instantaneous. There is not enough time for a capacitor to charge and discharge without effecting the ignition timing of the engine.
At that split second, the entire power of the stored spark is discharged at once,
The entire power of the spark is always discharged at once, in every system.
Originally Posted by Some BS site
creating a spark 300 times more powerful.
Ok, lets see. If a Saturn ignition system produces 45,000 volts to the spark plugs (not sure if thats the number but it should be close) then this product claims to boost that to 13,500,000 volts (13million volts). I'm not sure but that sounds close to a bolt of lightening.
I would suggest you not even consider, for a second, spending that kind of money on these wires. If you want to throw money away, i'll provide you with my address and you can send it to me. These wires will do nothing to make your car faster except make your wallet lighter.
Old 07-23-2006, 12:05 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
i am not as doubtful as catfuzz on this but for the price, i'm not going to try them( and i've heard they cause a lot of RFI)
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 07-23-2006, 11:33 AM
what about the Nology CoolWires Ignition Wires
Old 07-23-2006, 11:28 PM
No fancy spark plug wires are any better than a decent set of OEM wires unless you have a high energy ignition system which would require thicker insulation. Even in HEI applications, 8mm wires are more than adaquate. If you want pretty, then go ahead and pay the money but don't expect performance gains on a stock ignition system.
Old 07-24-2006, 10:58 AM
drew300 drew300 is offline
my stock wires are fine.
Catfuzz, electricity isn't instantaneous, but we are only talking of a few microseconds, so you're mostly right.
I've read about using a second spark gap to help old style (50's) ignoition systems. Maybe thats the "capacitor" in these wires. A bad plug could leak-off the energy before it could build to enough to spark, so by having a second gap, the energy built up enough to jump both gaps. But no- one has needed this in last few decades.
But I agree, spend the money else-where.
