1995 lumina runs HOT
I drive 4 or 5 miles and the temp. gauge goes to about 3/4 to just below 260
the reservoir fills up and bubbles. After it cools the reservoir is near empty. I've had the thermostat replaced and the fans are both working and the radiator flushed (and made sure that there is no air in the system). There is no water in the oil. There do not appear to be any leaks. I've had two mechanics look at it several times and they've run out of ideas. ( One did say a new water pump might help) Any thoughts would be much appreciated !!!!!! |
Re: 1995 lumina runs HOT
yea it could need a water pump, you had it pressure tested for leaks or does it appear to have none?
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles] Gone but not forgotten: 1995 Pontiac Grand Prix GTP[sold, 128k miles] 1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles] 1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles] 1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems] 1990 Hyundai Excel GL [died, 220k miles, died] |
Registered Offender
![]() Join Date: Mar 2006
At 260° and steam flashing off in the expansion tank, I'd guess that there was adequate pressure. Still, a test would be a good idea, both with a dead cold engine and fully hot one. A compression leak into the cooling system via cracks around the valve seats or spark plug holes, or a failing gasket, may not show up on a hot engine, but can on a cold one.
As suggested, checking the coolant flow would be a good idea. A slipping or eroded impeller on teh water pump shaft could be a problem, as well as restriction in the lower hose or within the radiator itself. |
"a test would be a good idea, both with a dead cold engine and fully hot one."
Good idea. Thanks. I'll try it. Also, I bought a new radiator cap. We'll see if that helps. |
