Old 07-24-2006, 01:39 PM
Carfreak18's Avatar
Carfreak18 Carfreak18 is offline
Send a message via AIM to Carfreak18
Engine timing?
Now I have seen my uncle shoot a timing gun?(i think its called) on the belt of the motor when it was idling..what exactly does this measure or time?
Holland Speedway
Lake Erie Speedway
Tioga Speedway (R.I.P)
Wyoming County Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Many more to come....
Old 07-24-2006, 02:52 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Engine timing?
Timing light, It flashes when your #1 cylinder fires and makes the crank look as if its standing still so you can see at what degree it is firing at.
Old 07-24-2006, 07:21 PM
Carfreak18's Avatar
Re: Engine timing?
I kinda understand what your saying,but I dont understand the crank part.
Holland Speedway
Lake Erie Speedway
Lancaster Speedway
Motordrome Speedway
Mountain Speedway
Eriez Speedway
Stateline Speedway
Old 07-25-2006, 11:35 AM
UncleBob UncleBob is offline
AF -Advisor
Re: Engine timing?
the timing light flashes every time the ignition fires on #1. On the belt pulley/crank balancer, there are numbers to give you a representation of at what particular degree the ignition is firing, with a pointer. So the light flashes, and you'll see the pointer a number or representation of a number line up and you'll know what the degree's of timing there is at idle.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
