Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-10-2006, 09:52 AM   #1
scottah
Angry Total Power Loss While Running
I have a 95 Ciera SL 3.1 that while driving will cut out completly. I'm talking everything cuts out, no lights, no hazards, no instruments, no power to anything, its like someone has disconnect the battery while im driving. I have a new battery, checked all connections to battery, alternator, starter and everything is good and tight no corrosion on anything. Battery is putting out 12vdc. I have looked at a wiring diagram for this car and after looking at it alot of this points to the EMC. I have checked the connections ast the EMC and it looks good too. No corrosion and good connections. Am I going in the right direction with this? Another reason I'm looking at the EMC is that I can disconnect the battery overnight and in the morning reconnect it and the car will start and run fine? Something is resetting, just don't know what. Please help.
scottah is offline   Reply With Quote
Old 07-10-2006, 04:33 PM   #2
maxwedge
A990 racer
Lightbulb Re: Total Power Loss While Running
Welcome to AF. This is typical of battery or chassis/engine ground problems, start there and do not assume tite is good, take em off clean em up and look close for corrosion in the cable ends everywhere.
Old 07-10-2006, 07:02 PM   #3
mrstg65
I once had a Monte Carlo where the negative battery cable completely corroded from the inside out. You could not tell because the plastic insulation
covered the problem area and both ends of the cable looked OK. This drove me nuts for about 2 months before I solved it. In my case everything went dead when you stepped on the brake pedal. Inspect your cables and their connections very closely. Good Luck!
mrstg65 is offline   Reply With Quote
Old 07-10-2006, 08:37 PM   #4
XGamesJ6
XGamesJ6's Avatar
friend had a similar problem, his solution was get a big black battery cable from walmart, and bolt it from the battery straight to somewhere on the engine, and then from there somewhere on the body, i think this was a crude idea, it worked, but i wouldnt suggest it, try replacing the one that goes to the body of the car, and if rust has takin over that part on the body, maybe find another spot to bolt it to, but be careful so you dont short anything out
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
XGamesJ6 is offline   Reply With Quote
