| Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums. |
Worst nightmare, 3.1L-V6 locked up, help
Okay here's one for the history books. I've owned a 94 Cutlass Supreme for 4-1/2 years, 3.1 liter V-6, had 116,000 miles, never had any trouble except for an alternator and starter, and clogged injectors. So I sell it to some people, they owned the car a whopping 8 days and call me to say the motor has "locked up" on them. Are you kidding me? They supposedly went in for groceries, the car had been running fine to that point. Come back out to go home, the car had trouble starting, then started, then had severe rattling noise, then died. The guy said he put a wrench on the crank and could not turn it over. They towed it and had a mechanic remove the starter in case it was binding the motor, no dice, he said it had a broken cam, or such, that the 3.1 liter engines were notorious for broken camshafts. I'm floored over this whole clusterfazoola. Has anyone else ever seen anything like this, esp when the car was running fine and then turned back on with a problem of this magnitude on these 3.1 liter engines? Help is greatly appreciated!
![]() Join Date: Jan 2005
Re: Worst nightmare, 3.1L-V6 locked up, help
That's unfortunate.
How much damage did the broken camshaft do? |
I haven't been able to find out yet, but I can't imagine there being major engine damage from a car that was running fine, shut off for the time to shop for groceries, come out, start up and rattle around then shut off, and then the engine supposedly locked up. At low RPM's and a cool engine, if it had oil and water, I find it nearly impossible that it would be locked up or have sustained "major engine damage." I'm not sure if the new owners are trying to con me into a refund of some sort or not, that seems more likely than their story about my former car.
#4 | ||
A990 racer
![]() Join Date: Mar 2002
#5 | ||
ask them if they did anything to the car, changed the oil added any fluids etc. Also make sure they didn't somehow bust the oil pan by driving over something. I understand that they may not be honest with you if they were at fault.
#7 | |
Yes, good point and I did ask the owner, or the owner's boyfriend. He claims that fluids were at their proper levels. I still have trouble believing this is a malfunction that is not an operator error. If it turns out that a cam, or timing chain is busted it will be a one in a million shot that I could have sold the car 8 days before it happened, after owning the car from Oct. 11, 2000 to June 3, 2006 and the engine craters on June 11, 2006.
#8 | ||
A990 racer
#9 | |
I could be wrong but somthing smells fishy...
in my famly we have 4 of these 3100's,, two of them have WELL over 200,000 miles, all running as strong as the day they bought them, not a major problem yet......
1999 GMC 3500 SRW 4x4 7.4 4:10's FF G80 2004 Chevrolet Impala LS 3800 "ALWAYS"...... full synthetic!!!
#10 | |
Sorry to Maxwedge, the "duh" meant I know if cam fails it'll drive the pistons into the valves making the engine toast. I'm just looking for info as to the history of these engines. I spoke to the mechanic today who says the 3.1's and 3.8 engines are "weak" and can break in the lower end, I guess the crank or rods, but I certainly don't hear that much about these engines just up and cratering like this. He said he pulled the plugs, put transmission oil in the cylinders to try and unseize the engine and no good, it's locked up, and according to him, will need a total replacement. Then he advises the owners to put a factory reconditioned long block in for $3000 incl parts and labor. In a car that cost them $2900? Duh to that for sure! I still have a hard time believing that I owned the car for nearly 5 years with no trouble at all, they've had it 8 days and it's totaled under the hood. I still think something is wrong with this picture.
#11 | ||
#12 | |
Well, I just offered to return a goodly sum to the new owners to help repair the cratered Cutlass. That's all I'm going to do, it's just bad luck (theirs), or that's what I'm going to chalk it up to, and not look back, I'm flushing this turd of a deal, and will still go on thinking if I owned the car today it'd be purring like a kitten. End of deal.
#13 | ||
A990 racer
#14 | |
It very well could be a cam failure. I will post the end result if and when I hear how this saga plays out. Being that I'm contributing to the repair cost, I certainly hope to learn the cause of failure. And I agree, lower end issues do not seem to be all that problematic on 3.1 or 3.8s. I have a 3.8 in an 95 LSS 88, and it's a very good engine, knock on wood, with 142,000 miles and still cranking strong.
#15 | |
The Cutlass suffered some sort of damage caused by a valve seat on the head that came loose and dropped on top of the piston and eventually locked up the engine. It was not a broken cam as one idiot mechanic thought. Had these new owners taken my advice, they would have had a mechanic pull the heads and try to figure out what happened before deciding to drop a rebuilt engine in. As it turned out, all that was needed was a new head and a piston and they would have been up and running. As it turned out they put a rebuilt long block in from Autozone and that engine was bad also so the guy ended up pulling that one and putting in a second engine from Autozone. It appears that this fiasco is finally over, but a good lesson learned, always diagnois the problem fully before making a decision that may not be the right solution. A head change and piston replacement would have been less costly than the route they took for sure.
Does anyone know exactly how the 3.1 engine heads are made up, that allows a valve ring seat to break off and drop into the cylinder? Thanks to all! |
