Go Back   Automotive Forums .com Car Chat > Chrysler > Lebaron
Old 07-09-2006, 01:50 PM   #1
wsg
Traany Problem No Code?
I have just aquired a 94 convertable with a 3l and auto transmission it is in limp mode and I am tring to figure out the problem before sending it to a shop since I don't know one that I trust (im north of Toronto) all shops want to do now is rebuild trannys not fix a problem, my son works at the local garage and took it in he said it showed no tranny codes so iwas wondering if anybody had any ideas I have read about some bad wiring issues but figured they should throw a code just looking for a direction here I plan on inspecting all conections tommorrow, I am in the middle of doing a tune up and checking the compression before I start to spend money on this car don't know how accurate my guage is but shows all 6 between 120-135. The car did show some engine codes like to rich to lean but I figure these could be from running in limp mode....BTW even in Limp mode I like this car hope I can work the bugs out
Sean
wsg is offline   Reply With Quote
Old 07-10-2006, 10:12 PM   #2
94LebConv3La604
Re: Traany Problem No Code?
If we're gonna give you any ideas as to what could be the problem you will have to elaborate on what's going on a little bit more. How is the tranny acting and what does it do before it goes into limp mode? How was the tranny acting before this happened? How many miles? Just give some background on it.
94LebConv3La604 is offline   Reply With Quote
Old 07-11-2006, 07:07 AM   #3
wsg
I Just got the car don't have the background other than 211 km changed filter and fluid yesterday no change found rebuilders tag called them they say tranny was rebuilt about 5 yrs ago by the number but this is the only info I have did find a bad wire and am going to lookl thru the harness today if I ge time
