Old 06-05-2006, 12:13 PM   #1
jesurban
Exclamation Single Mom needs Help!!
I have a 1992 cavalier. I know something about cars but not much so I will do my best. First the starter went out so I got that replaced. Then my battery was dead so I had that tested and they said I needed a new one. Did that. After I did that though my battery light was on in my car, never was before. NOW, the battery is dead, I can pop it and it will start and run for about a minute and then it just dies. It won't keep running. I am not usre what to do next. I replaced the alternator about a year ago...with a used one. I don't know what to do and really need some sort of help. Thank you.
jesurban is offline   Reply With Quote
Old 06-05-2006, 01:09 PM   #2
OverAllComa
Send a message via AIM to OverAllComa
Re: Single Mom needs Help!!
Battery light is usually battery or more likely the alternator. A lot of big-name parts shops should be able to test the current coming off the alternator. Get it done. Oh yes, and if you need a new one and plan on doing it yourself, you can save a few bucks by getting a remanufactured one. Same warranty, cheaper part.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
OverAllComa is offline   Reply With Quote
Old 06-05-2006, 02:24 PM   #3
jesurban
Thank you I will look into getting my alternator tested.
Old 06-05-2006, 05:48 PM   #4
OverAllComa
Remember, you need to be cranking around 14.4V from the alternator. Below 14V and you're gonna be in trouble.
Old 06-05-2006, 11:18 PM   #5
dcfoster83
Smile Re: Single Mom needs Help!!
I would agree with OverAllComa, its probably your alternator... your battery would be the problem... when the car is running you don't actually need the battery to keep it running if your alternator is putting out strong enough you... a cheaters way of testing that would be to pull your negative battery cable off and see if the engine stops right away...from my experience that usually means the alternator is dead or the wire to the alternator isn't tight.
dcfoster83 is offline   Reply With Quote
Old 06-06-2006, 08:50 AM   #6
jakegday
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
just curious, did you think you'd get more help by saying your single??
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
jakegday is offline   Reply With Quote
Old 06-06-2006, 10:27 AM   #7
OverAllComa
"Single" doesn't imply "and looking." I think the implication to the statement was that, as in most situations where there's a single mom, money is tight and time is scarce to even try to fix things yourself. There's also this stereotype that women don't know things about cars, and although false, it was probably being appealed to here.
Perhaps more than anything this person wanted their car fixed and needed a subject line for it. Ya know, sometimes a cigar is just a cigar.
Old 06-06-2006, 11:21 AM   #8
jesurban
Thanks OverAllcoma for that response. You hit that one on the head. I guess i could have just said Mom needs help but then I might have been impling that the other half is an idiot. Anyhow I apperciate all of the advice and will let you know the out come. thanks again......Mom
Old 06-08-2006, 11:25 AM   #9
Helmuth48
Helmuth48's Avatar
Just a note....Where I live in SC....the Advance Auto or AutoZone will test the battery/ alternator for FREE......
If you need a Battery...they will install it for Free also....
Good Luck....
Helmuth48 is offline   Reply With Quote
Old 06-23-2006, 05:50 PM   #10
car crazy
it's the alt. had one.But i check battery.then starter then alt. last that's wat it was replace it with a new 1 not second hand
car crazy is offline   Reply With Quote
Old 06-28-2006, 12:17 AM   #11
z24-xavier
Wink Re: Single Mom needs Help!!
even though i have to agree with the last post about new better than used, but there IS an inbetween. there are 2 choices, either find a gm wholesaler (kinda hard to find an HONEST one these days though, not my perferred choice) OR find an auto-electric shop. this is a shop that is dedicated to nothing but fixing and rebuilding automotive electrical stuff, especially alternators. going this route will not only make it cheaper *if you dont have them install it that is* but it will be completely rebuilt with quality parts as opposed to no-name brand reman. alternators which can bite the dust very easily especially it seems when the time is worst to happen. get it done by professionals with quality parts for cheaper, and it's still your stock alt.
"this has been a public service announcement from.. your mamma's bedroom"
cavalier z24 2.3 or Fiero 2.5???
I HAVE BOTH!!
z24-xavier is offline   Reply With Quote
Old 06-28-2006, 06:30 AM   #12
pitbull781
I have worked on cars most of my life so to me this isnt anything new if your battery goes dead its usually the fault of the alternator and replacing it with a used one is usually not a good idea. I understand that its cheaper but it ends up being more expensive in the long run. Get your new alternator and your problem will be solved.
pitbull781 is offline   Reply With Quote
