Old 06-24-2006, 12:20 PM   #1
D_LaMz
D_LaMz's Avatar
Tamiya P2000 the same as other grits?
Before I go outand buy some sand paper and Tamiya compounds, I want to know if P2000 is the same as 2000 grit because I see people always saying to use 2000 grit to take out light orange peel. I checked here https://www.micro-surface.com/default.cfm?page_id=174 and it says P2000 is the same as less than 1000 grit. What is up with that?
I also searched and came up with nothing.
D_LaMz is offline   Reply With Quote
Old 06-24-2006, 12:26 PM   #2
Some_Kid
Some_Kid's Avatar
Re: Tamiya P2000 the same as other grits?
i belive 2000p is the sAME at 2000 grit
Some_Kid is offline   Reply With Quote
Old 06-24-2006, 12:26 PM   #3
cyberkid
cyberkid's Avatar
Each company's way of calculating the grit is somewhat different. I've reed somewhere that Tamiya's 2000 is around micro mesh's 3000-4000.
cyberkid is offline   Reply With Quote
Old 06-24-2006, 12:31 PM   #4
D_LaMz
D_LaMz's Avatar
IF thats true then I'm gonna use the P2000 to take out the light orange peel and follow up with Tamiya Fine, Finish, and wax.
Old 06-24-2006, 06:00 PM   #5
hirofkd
hirofkd's Avatar
This chart might help.
http://www.calbex.com/33.htm
Tamiya's sand paper should be complying to the Japan Industrial Standard 6001, and from the chart, 2000 grit of the JIS seems almost the same as P2500 of FEPA/ISO6344.
Hiroaki Fukuda
hirofkd is offline   Reply With Quote
Old 06-24-2006, 10:05 PM   #6
D_LaMz
D_LaMz's Avatar
Thanks for the help, but I picked up the PolishingStiX because they ran out of Tamiya's sandpaper and they ran out of Tamiya fine and finish compound. Guess I'ma have to use my Scratch X and Tamiya Wax.
OT: Hey hirofkd I see you are in Houston, where do you go to get stuff? I mainly go to Hobby Lobby and HobbyIsland.
