Old 05-08-2006, 01:06 PM
goser goser is offline
Spark Plug Wire Recommendations
I just metered my spark plug wires...my chilton manual says to replace them if the resistance is over 25Kohms, well all of mine are 800-1000 ohms except for #3 which is 9000 ohms (that plug was also way more carboned up when I replaced them) so I think I'll swap them out next time I get some cash flow. Wondering what people recommend for replacement wires. I know you're going to say Delco, but they're real pricey. Anyone had experience with Bosch, Champion, NGK, etc.? What are the best wires out there?
Thanks!
L.
Old 05-08-2006, 03:15 PM
OverBoardProject OverBoardProject is offline
Banned
Re: Spark Plug Wire Recommendations
If you plan on keeping your Blazer for several years you'll probably want to keep the origional equiptment wires. They'll last longer than the rest put together
Otherwise Bosch would be my second choice.
{edit} if you live by a race track you might be able to buy a used set from some racer. They often replace things like very good quality plug wires yearly just to ensure that they won't have any problems.
Old 05-08-2006, 03:40 PM
Hmmm...that's a great tip about the race track, and I happen to work right by one...thanks!
Old 05-08-2006, 04:03 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
im runnin accell extreme 9000's and they perform very well, and last a long time. they were, however, $75 for a set.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 05-08-2006, 04:29 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
great advice from a great person... however... stu is old school, our wires won't be commen off a race car because of the re-designed cap... don't tell any one, but for my personal vehicals i use napa wires, good quality, lifetime warrenty, and cheeper, my cost almost 40 bucks cheeper then the delcos (can't give you an otc price, i get discounts through my shop, but my shop cost on delcos were 95 bucks, and the napas were 60ish... thats a v8 s 10, but im sure the 4.3's are close in price)
Old 05-08-2006, 10:04 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
I would go with taylor wires. I use them in my camaro, both my trucks, great wires and an upgrade from the stock delcos as they have less resistance per foot.
Old 05-08-2006, 11:46 PM
BlazinMlew's Avatar
BlazinMlew BlazinMlew is offline
Send a message via Yahoo to BlazinMlew
I belive Summit sells the Accel kit (Cap, rotor, plug wires, and (crap) plugs) for about $150 of you are going to do one you might as well do it all if you got the cash and all that jazz.
2000 Blazer 4WD 2Door
http://www.cardomain.com/ride/2324297
06 Pontiac G6 V6 Coupe
http://www.cardomain.com/ride/2371527
Old 05-09-2006, 11:00 AM
ZL1power69's Avatar
GM S-Series Mod
i did buy that kit when i did my tune up/cpi replacement (used ac delco plugs though), but the original question was directed specifically toward plug wires.
Low 11 sec sleeper
My Cardomain
Old 05-09-2006, 07:13 PM
RJ MALIBU's Avatar
RJ MALIBU RJ MALIBU is offline
go with taylors,very good wires added a little power and economy,also you can get them in different colors if u like that stuff ,try ebay igot mine 4 50 bux
1997 Blazer w/99+front end with clear Euro Projector Headlights and parkinglights and cai 2 -12'' Dual subs 600w RMS 600 watt kenwood amp Sony head unit
2003 malibu-bone stock(wife's car)
Old 06-11-2006, 02:18 PM
magnum3456's Avatar
magnum3456 magnum3456 is offline
Banned
should i replace spark plug wires?
i checked one and it said 1226...divide by 2 because its 2 feet long and i get 613....and 51 per inch.....should i replace them or not?
Old 06-11-2006, 03:16 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Thanks!
L.
Forget the ohm out process. It only tells you if they are real bad.
Not a real good test on wires. It takes a engine scope to tell good from bad.
With the 75 to 125K plug replacements it is a good time to replace wires.
Normally you can tell by the price how good they are.
Good one are going to cost you but they only hurt one time.
Them cheapo ones will bit you in the rear many times.
MT
MT
Old 06-11-2006, 07:44 PM
2000blazerls's Avatar
2000blazerls 2000blazerls is offline
I like the Taylor HP wires. Got a set in red and they are super quality.
Bye Bye Blazer!
http://www.cardomain.com/ride/2159611
Hello Monte Carlo!
http://www.cardomain.com/ride/2445379
Old 06-11-2006, 09:21 PM
00BlazLT's Avatar
00BlazLT 00BlazLT is offline
I ran across this awesome deal a while back. The plugs are (were) platinum and the price cannot be beat. If you feel safe usin eBay theres no better way to go plus the sellers feedback is great.
http://cgi.ebay.com/ebaymotors/AC-De...2196QQtcZphoto
Not sure if the years this setup covers applies to the original posters blazer but it certainly covers mine and many others.
2000 Blazer LT 4 Door 4 x 4
K & N FIPK
Magnaflow/Duals
Clarion/Polk/Rockford Fosgate
Old 06-11-2006, 09:41 PM
ac delco wires, my cost, from my delco supplyer is 6 bucks more then that price for every thing after shipping is figgured in
Old 06-12-2006, 06:03 AM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
OEM wires are all an engine needs.
I used to run taylors and had them for over 10 years but they were no better then stock wires.
