Go Back   Automotive Forums .com Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-04-2006, 02:24 PM   #1
tboneshep
Where is the Fan Relay, passenger side Cutlass Supreme 1991
1991 Cutlass Supreme, 3.1 ltr. Dual Fans, weve tested both fans on drivers side circuit, they both work. The Passenger side will not come on when it's on it's own circuit. If there is a passenger side fan relay, where is it? Could it be something else, in-line fuse? Checked other fuses, they are ok. Any ideas? Thanks
tboneshep is offline   Reply With Quote
Old 06-04-2006, 09:59 PM   #2
XGamesJ6
XGamesJ6's Avatar
Re: Where is the Fan Relay, passenger side Cutlass Supreme 1991
ive wondered why mine doesnt go on as often either, i later found out it does go one, when the engine gets really hot, also it was only on when the AC was on, could be somethin with the A/C
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
XGamesJ6 is offline   Reply With Quote
Old 06-04-2006, 10:13 PM   #3
tboneshep
Well, after looking in the Owners manual (Doah) and learning how to READ, I discovered that the Auxillary Fan relay is located under the hood, passengers side, front fuse area, and is a 5-pin box type relay. I've tried several workin relays and can never see the passengers side fan come on! I found this information in another post on another web site and wonder if it applies:
GMMerlin08-12-2003, 06:37 AM
The cooling fans are controlled by the PCM and are turned on at a predetermined tempature.
The primary cooling fan turns on at 225 degrees and the secondary fan will turn on at 232 degrees. They should cycle....turn off when the temp cools off to about 215.
Found this info on a 94 cutlass at
http://www.automotivehelper.com/topic127061.htm
Any truth to this information as it pertains to our 91?
Old 06-05-2006, 08:15 AM   #4
XGamesJ6
XGamesJ6's Avatar
i would think so, thats kind of how my 93 works, and i dont doubt that its been that way since 90 or 91
Old 06-05-2006, 02:45 PM   #5
niccaleb112602
there is a fuse that powers that relay, also on that side of fuse box. I think its marked ingition. Had the same problem with the ac compressor not working and pulled the relay and jumped batt+ to one side and it all came "alive" found that fuse blown and it worked fine after that. i think there is also a fuse under glove box but it controls your flapper doors.
niccaleb112602 is offline   Reply With Quote
Old 06-09-2006, 06:58 PM   #6
XGamesJ6
XGamesJ6's Avatar
take a mutli-meter or continuity tester, something that beeps or lights up when theres a complete circuit, and check every fuse you can find in your car, under the dash and under the hood, just touch the tester to the two metal points on the end of the fuse, and if u find one without a beep, or that doesnt light up, chances are thats blown.
