Go Back   Automotive Forums .com Car Chat > Chevrolet > S-10
Old 06-01-2006, 09:39 PM   #1
dvsguyca12
s-10 heater doest work
My heater has been out for a while a mechanic told me it is possible because i changed my thermastat to a lower tempature one is that true... Or is it more likly to be a clog in the heater core?
dvsguyca12 is offline   Reply With Quote
Old 06-02-2006, 11:54 AM   #2
OverBoardProject
Banned
Re: s-10 heater doest work
Welcome to Automotive Forums
T-stat is possible, but I'd think that the plugged heater core is more likely.
Using a prestone flush kit and see what happens. We're really suposed to flush the system every second year anyways
OverBoardProject is offline   Reply With Quote
Old 06-08-2006, 08:54 PM   #3
CELDesign
CELDesign's Avatar
Most likely it is your thermostat, on my '99 4.3 liter when the thermostat went bad the heat did not work...when I replaced it the heat worked again. On the S-10's with the 4.3 the thermostat is backwards, they stay cool and don't produce heat.
CELDesign
1999 Chevrolet S-10 Ext. Cab 4WD
SPECS:
Engine Code: 4.3 Liter “X” Code
Transmission Model: Electronic Automatic
Suspension: Increased Capacity
Colore: Lt. Pewter
CELDesign is offline   Reply With Quote
Old 06-09-2006, 12:26 AM   #4
hondaboy16v
Send a message via AIM to hondaboy16v
a lower temp thermostat is not the greatest idea with the 4.3, this motor tends to be very particular when it comes to operating temperature. However, changing back to a 195 thermostat would be much easier, so try that first. To be honest though, it probably won't help. Overboardproject is right, do the system flush. Your best bet (after flushing the entire system) would be to disconnect both heater hoses and buy a fitting from auto zone or the like that wil allow you to attach a water hose to the OUTLET hose running from the heater core. Then attach the hose to a faucet and crank hot water through the heater core until the water runs clear. Running the water through in a reverse direction will help break up deposites that may be keeping the core from working properly. We did this to my 95 and that core puked sludge for a minute solid. Been working fine ever since.
hondaboy16v is offline   Reply With Quote
