Old 05-31-2006, 11:50 PM
triplerc triplerc is offline
Send a message via AIM to triplerc
PROBLEM 3.1 car RUNNING BAD!
okay guys i posted about this before,
my 92 lumina 3.1 car is having problems! here to start off ill list the parts ive replaced, spark plugs, wires, ignition control module, had coils tested at autozone came back as good, new fuel pressure regulator, new crank position sensor, oxygen sensor, and a couple of odd and ends,
now to the problem:
started small, now big, i would be driving and the car would just be cutting out once in a while, motor would stall at stop signs, and stuff,and now i cant keep it running, when its running its real rough , running SUPER rich, back fires, getting it started is a task. i have to pump and hold the accelerator to even get it to seem to want to start.
reall getting to be a hassle to fix it, im thinking its prolly the fuel pump, or coils, fuel filter was replaced a year ago, guess wouldnt hurt to change it.
could it be out of time?
BTW no engine codes either.
Old 06-01-2006, 12:36 AM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: PROBLEM 3.1 car RUNNING BAD!
The fuel pump could be the culprit, so next time it dies, turn off the key and stick something in the fuel pressure test port and note if any fuel or air bubbles come out. If pressurized fuel is the only thing that comes out, then i'm 99% sure the pump is good. What i'm leaning towards is an overheating coil.. You can pick one up at autozone for about $20. An extra "known good" coil is handy to have when dealing with a hot coil. Just keep swapping them until you find the culprit.
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 06-01-2006, 01:06 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
is it intermittant, or alwyas will not start and run good? could your timing chain have some slop in it and be causing it to run real rich? just a thought.
-2000 Grand Prix GTP 170,000mi (daily driver)
-2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal)
-1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix])
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
"I'll Keep my Guns, Freedom, and Money. You can Keep the Change!"
----->>>>> Did You Know? <<<<<-----
Old 06-01-2006, 08:02 AM
wcamaddox wcamaddox is offline
Does your car need to have the crank position sensor calibrated(i think thats the word im looking for). On some gm cars when its replaced the ECM needs to "learn" the new signal its getting from the sensor.I dont know if yours does but its worth looking into.
