It has begun...
Okay, I bought the engine,and it's at the shop along with some miscellaneous accessories I thought I should have replaced while everything's apart. Below is a list of the new stuff I've bought to put onto the new motor. The engine comes with the oil pump, oil pan, timing chain, timing cover, and cylinder heads (typical long block).
New Items: Aluminum Radiator Clutch Fan Ignition Coil Upper and Lower Radiator Hoses O2 Sensors (both) Water Pump Power Steering Pump Plugs/Wires Thermostat Alternator Is there anything else you guys think I need to replace while the engine's out? They're starting the work tomorrow, so please throw your ideas in here asap! Thanks! |
Re: It has begun...
Replace the front seal in the transmission.
Re: It has begun...
New Motor Mounts
Re: It has begun...
Yeah, the mounts are less than a year old, so the mechanic's going to check those out for me.
As for the transmission seal, I'll talk to him about that too. Thanks guys! Keep 'em coming! |
