Go Back   Automotive Forums .com Car Chat > BMW > 7 Series
Old 08-27-2005, 01:14 AM   #1
mmanley
Question 2000 740il dtc p1622
Anyone have any ideas what causes this trouble code? Engine runs fine, coolant temperature is ok. The code indicates "map cooling thermostat control circuit electrical".
mmanley is offline   Reply With Quote
Old 01-03-2006, 10:53 AM   #2
apaulster
Re: 2000 740il dtc p1622
I have the exact same code and problem and failed inspection because of the code. I am curious as to what makes the code appear and am told by service that it is relatively common. Let me know if you found out how to fix the problem.
thanks,paul
apaulster is offline   Reply With Quote
Old 01-07-2006, 11:03 AM   #3
mmanley
Smile
I replaced the thermostat around 12/1/05 to cure this DTC in my car, no check engine light has occured since. Hope this helps.
Old 01-09-2006, 01:21 PM   #4
apaulster
Thanks, will try the same thing
Old 06-07-2006, 10:35 PM   #5
nbxguy
Did the thermostat change resolve your problem with the p1622 error as well?
Thanks.
nbxguy is offline   Reply With Quote
Old 06-08-2006, 08:23 AM   #6
adm77
Smile Re: 2000 740il dtc p1622
Hello there, that map thermostat fault code is caused by an internal fault within the thermostat circuit. By replacing the thermostat and housing (has map sesor incorporated in it) you will do away with your fault. This fault is very common and is of no real concern, but if it is causing you trouble with your countries testing procedures i would definetly change it. good luck.
adm77 is offline   Reply With Quote
