Onboard Air
Any looked at mounting an air tank above the drive line next to the mufler?
Re: Air Tank
A a matter of fact I did! I did a 3" body lift and I saw all of that "wasted space, a perfect place for an air tank! I would probably mount it to the frame on the crossmember underneath the back seats. That way it is a little more protected.
Packman |
![]() Join Date: Jul 2001
where the spare was...
I have my spare removed from underneath (doesn't fit anymore), and was eyeing up the space where it was for dual air tanks. Not sure where to fit the compressor, though.... I'd like to fit dual batteries in the engine bay, that would pretty much make sure an air compressor didn't fit there. I'd try to fit an air compressor underneath if I could find one that had a remote-able air intake and could stand being submerged.
Submerdged?
I have yet to see one, you could probably use a plastic battery box and seal it somehow. and Iam sure you could easily fab a remote intake. I would route it through the "air flap" on the passenger side.
![]() Join Date: Mar 2001
Has anybody though about using the PowerTank sytem? I know they are $300+ but, it seems like a more compact system you could mount in the cargo area? I am considering that as my source of air for my ARB air lockers when I get them.
We don't give a damn how loud your stereo is! Did you read your owners manual yet? V.P. of PNWX |
#6 | ||
Re: Submerdged?
#7 | ||
Re: PowerTank???
#8 | ||
Re: PowerTank???
#9 | ||
Re: Re: PowerTank???
#10 | |
Helium and O2
Having breathed both of those gases before I am sure CO2 would be rated at the same pressure? Been too many years......Will investigate it further.
#11 | |
The only reason I wondered is the constant pressure in a Power Tank. It's at 3000 psi right up until there is nothing less, because the CO2 evaporates and creates air (is there a physics major in the house?).
Plain air in a scuba tank starts at 3000 psi for a good fill, then drops off to 500 when you head back to the boat (although I was always empty when I surfaced . |
#12 | |
Here is the writing that is on the bottle. Maybe someone can make sense of it.
3AL CTF/DOT-E6498-1800 20#C02 U713410 Luxfer A 5 80 |
#13 | |
AF Premium User
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2001
There has been quite a few posts on doing your own CO2 tank on another list I monitor. Most people seem to recommend going to a welding supplier or home-brew beer web site.
#14 | ||
#15 | ||
I am told that you can use a welding tank which will hold more air, but is heavier. From the pictures I've seen in magazines of the power tank, it appears to be made of some type of alloy similar to my tank. My tank is pretty heavy, so maybe people aren't using welding tanks because of the weight issue? My tank currently has about a 1100 pounds of pressure in it, but it has been about a year since I had it filled up. I am not sure how much pressure the tank holds when it is full. |
