Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier
Old 04-23-2006, 04:34 PM
gardnerr06 gardnerr06 is offline
91 z24 cutting off when stopping
i've got a 91 z24 automatic that is cutting off sometimes when i get stopped. other times it will act like is going to cut out, rough idling up and down for a few seconds and then it will straighten out and idle fine while stopped.it did this about six months ago for a day or two, then it quit just as fast as it started. any chance it could be a vacuum line or pcv valve, or any suggestions?
Old 04-24-2006, 04:12 AM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: 91 z24 cutting off when stopping
Do a search on TCC Solenoid, see if any of the posts match your symptoms.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 04-24-2006, 04:48 PM
it has cleared up. just as quick as it started. i already had the tcc replaced a few years ago. it was doing it even when i manually put it in neutral. i did put some premium in the tank just before it stopped. bad gas?
Old 04-25-2006, 03:35 AM
dirty injectors
Old 04-28-2006, 04:39 PM
it does this after i disconnect the battery, i just noticed that. after a few hours of driving it goes back to normal. what's going on?
Old 04-29-2006, 11:48 PM
OH! That's an important detail you left out, isn't it? The idle air flow and such is controlled by the computer. Unfortunately, it learns all the right things to do by actually doing it but also clears the memory when the battery's disconnected for a few minutes. Its supposed to happen, don't worry. There's an actual process to go through to relearn the idle, but it can also be done by just driving around and not freaking out when it dies.
