Go Back   Automotive Forums .com Car Chat > Cars in General > Exterior | Bodykits | Lighting | Aerodynamics
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications.
Old 04-16-2006, 08:35 PM   #1
DuniCraig
Primer Problem
This is the first time Ive painted a car with pro paint and Iam having problems with the primer. I painted the primer on with my gravity feed spray gun and when i was done i took of the cap to clean it out with paint thinner and after i put all the thinner thru the gun it didnt work. A thin layer of primer was left on the walls for the cup and little chunks of it were sitting at the bottom of the cup, thankfully the gun has a filter. I had u clean it with the Urethane Activator. I used Nason 421-19 2K Urethane Primer and mixed it with the 483-87 Activator, in a room around 70 degrees. Could it of been that i didnt put enough of the activator in it or to much? Thanks
DuniCraig is offline   Reply With Quote
Old 04-16-2006, 08:49 PM   #2
AlbanyCartel
AlbanyCartel's Avatar
Re: Primer Problem
you should ask in the "detailing" section
sorry, i couldn't be of more help
AlbanyCartel is offline   Reply With Quote
Old 04-20-2006, 10:01 AM   #3
jveik
Re: Primer Problem
i had that happen the first time i tried to use this wierd type of primer called epoxy... it was because i had never painted a car before, so i tried to mix the paint in the cup on the gun lol!!! it turned all globby and stuff and it took over an hour to clean out the gun
jveik is offline   Reply With Quote
