Go Back   Automotive Forums .com Car Chat > Mitsubishi > 3000GT/Stealth
Old 09-01-2006, 02:12 PM   #1
chopstick1981
clutch problems
i just bought a 94 stealth and am having trouble with the clutch. To shift gears in my car i literally have to absolutely floor the clutch to disengage it enough to catch a gear and even then its a little rough to catch the gear. I need to somehow adjust the clutch so it disengages higher up on the pedal. I've already flushed the hyd clutch with new fluid and bled it, but it doesn't seem to be helping. any help would be appriciated
chopstick1981 is offline   Reply With Quote
Old 09-01-2006, 02:42 PM   #2
AutostradaVR4
Re: clutch problems
the clutch pedal is adjustable if i recall correctly.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
AutostradaVR4 is offline   Reply With Quote
Old 09-01-2006, 03:00 PM   #3
sLADe781
Re: clutch problems
Yes, the clutch is adjustable but make sure you have all the air out of the system first. I say that because I bled my system like 3 times but still had air in there and my clutch was somewhat spongy and caught earlier than what it used to. I was to the point of adjusting the clutch pedal as well but gravity bled it a final time and got rid of all the air. After that, everything felt fine and went back to normal. Good luck!
sLADe781 is offline   Reply With Quote
Old 09-01-2006, 05:19 PM   #4
chopstick1981
Re: clutch problems
so how do i go about adjusting it? is the adjustment at the pedal or is it at the slave cyl?
Old 09-01-2006, 05:40 PM   #5
AutostradaVR4
Re: clutch problems
its in the pedal. I know that you do it from inside the car, unfortunately ive never screwed around with mine so im not sure of how exactly you do it.
Formerly BlinkRA182
Old 09-01-2006, 07:29 PM   #6
sLADe781
Re: clutch problems
There's a locknut that you have to "break" and then spin the rod.
http://www.3si.org/forum/showthread....er+replacement
The third blurry picture points to the nut.
Old 09-01-2006, 07:45 PM   #7
Linebckr49
Linebckr49's Avatar
Send a message via AIM to Linebckr49
Re: clutch problems
how many miles do your 94 stealth have on it?
if pedal adjustment doesn't help, then your slave cylinder might be on its way out.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Linebckr49 is offline   Reply With Quote
Old 09-02-2006, 05:52 PM   #8
chopstick1981
Re: clutch problems
ok... wow...thanx, i got in there and udjusted that shaft like you showed in the picture and now i can easily shift through the gears. Although 3rd gear needs full throw of the clutch pedal while the others only need about 1/2 to 3/4 a push on the clutch. Does that sound like a wearing synchro?
Old 09-02-2006, 09:31 PM   #9
Linebckr49
Linebckr49's Avatar
Re: clutch problems
synchro? where did you get that?
a wearing synchro will give a grinding noise/feel when shifting gears. if you're engaging all gears with 1/2 push of cluth, but 3rd requires a full push, it sounds like either your slave or master cylinder is going out.
93 3000GT base
