Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 03-30-2006, 09:12 AM
jeepndanes jeepndanes is offline
'99 Rodeo stalling when decreasing to low speeds
Well, the old Rodeo isn't what she used to be. The fuel sending unit is out (will be replaced this weekend), the rear lift gate is squeaking like crazy (no idea why), and the EGR needs a serious cleaning. The latest problem has been stalling. It has been stalling when I slow to either go around a tight turn or stop at a toll booth. It has only happened about five times, but it could be dangerous. Everything is progressing normally, and the engine simply dies. The rest of the vehicle still has power, but the engine stops. I haven't noticed a pattern in the occurances other than slowing down.
Do you folks out there have any ideas?
Old 03-30-2006, 10:42 AM
Mirock Mirock is offline
Re: '99 Rodeo stalling when decreasing to low speeds
As far as stalling problem it might be related to bad fuel sending unit ,do you have a CEL on, how many miles on it ,when it was tuned up?.About a squeekie tail glass ,i used to have the same problem ,(it was driving me nuts )In my case it was a loose latching rod on a tail glass it is a thing that latches in to a lock in a tail gate it is held by 2 philips head screws with a rubber washers mine were loose,the whole thing was moving creating a squeeking noise. Hope this will help.
99' rodeo 4X4 LS
99' mazda 626 wife's toy
Old 03-30-2006, 12:09 PM
mapua82 mapua82 is offline
Had the same problem before the IMG was replaced.
'99 Rodeo SLE 3.2L V6
'01 Camry CE 2.2L
Old 03-30-2006, 01:03 PM
IMG? What's that?
Old 03-30-2006, 01:09 PM
IMG= Intake Manifold Gasket
99' rodeo 4X4 LS
Old 03-31-2006, 08:09 PM
2eyefishclaw's Avatar
2eyefishclaw 2eyefishclaw is offline
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
bad fuel sending unit will not cause a die out
a fuel pump on its way out can cause this but its not very likely that this is the problem.
open the hood start the vehicle on the drivers side there is a harness that runs from under the P/S resivoir and goes up along the side of the intake manifold remove the bolt that secures the harness to the drivers side valve cover gasket grab a hold of the harness pull twist and tug on it to see if the engine stalls if it does there is a problem in that harness E-mail me if that is the case I will tell you how to find and repair it or them. [email protected]
Old 04-12-2006, 10:43 AM
Well, I got a few suggestions on the board here and via PM.
I checked the IMG by spraying carb cleaner at it... no increase in idle. The electrical connections are all tight and harnesses are fine.
Someone recommended an o-ring on a fuel check valve... I am not sure what that is, neither is the dealership in town. Can anyone expand on this?
I was going to change out my IMG and injector o-rings, but am not certain that is really the problem now...
Ideas?
Old 04-16-2006, 01:40 AM
stanger42's Avatar
stanger42 stanger42 is offline
Send a message via AIM to stanger42 Send a message via Yahoo to stanger42
i had what sounds like a similar problem in my 94. I replaced the fuel filter and that fixed the problem. (the thing was pretty gunked up)
