Old 04-11-2006, 12:37 PM   #1
Ramblin Fever
Coolant hoses - There are 12 coolant
hoses, and by-pass hoses on these engines. 4 of them are routed to the oil cooler and back to the block, and 8 of them are primary for the engine itself.
How many of you have replaced ALL 12 of these hoses?
2 Radiator (upper/lower)
2 heater hoses
2 throttle hoses
1 by-pass
1 oil cooler pipe to block
1 oil cooler to oil cooler to pipe
2 feed & return hoses at oil cooler
1 (3 peice) Vent T-hose (under the top of the engine)
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Ramblin Fever is offline   Reply With Quote
Old 04-11-2006, 12:44 PM   #2
directory
directory's Avatar
Re: Coolant hoses - There are 12 coolant
do you need to change them al out? i'd say only replace the warn/ bad hoses as they go bad.
but i guess preventative maintainance is good.
you just about have a brand new engine don't you???....
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
directory is offline   Reply With Quote
Old 04-11-2006, 06:09 PM   #3
surferfletch
I didn't get them all, but I got most of them. I also changed out the larger of the 2 coolant pipes up top. It was getting corroded. $70 I think. Should last the life of the rig.
surferfletch is offline   Reply With Quote
Old 04-11-2006, 06:41 PM   #4
directory
directory's Avatar
would it be worth going with a larger hose? (if such a thing) to hold more coolant?
is that possible?
SKYWARN
we be clubbin'
--B
Old 04-11-2006, 06:52 PM   #5
Ramblin Fever
The edges of the 2 top heater core to block pipes on mine had a bit of corrosion. Didn't change them out though, didn't look too bad.
1997 3.2L V6 Rodeo
Old 04-11-2006, 07:35 PM   #6
marcre
marcre's Avatar
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
I just bought the upper and lower radiator hoses at Advance Auto, this thread has me thinking I should change the others as well. They do look like a pain to get to.
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
marcre is offline   Reply With Quote
Old 04-11-2006, 09:24 PM   #7
Ramblin Fever
Trying to "prevent" from having to have a brand new engine actually - everything internally in the engine itself is original.
Just major preventative maintenance, as I've had to replace an engine before on another vehicle do cooling system failure - it's not pleasant. If I didn't like the truck so much, or if I was interested in selling/trading within the next year, I wouldn't worry; but she's a keeper, runs REAL good, and with the exception of these last 6 months, haven't hardly put a dime in her in 9yrs. Besides, if I keep her on the road another 3-4yrs, I'll regain every time put in now and then some.
1997 3.2L V6 Rodeo
