Go Back   Automotive Forums Car Chat > Dodge > Caravan | Voyager
Old 11-05-2005, 10:13 PM
Mbriggs Mbriggs is offline
Angry Power Steering leak-Help Needed
The power steering resevior is leaking very badly on my '98 3.3l caravan. 2 questions:
1) Are there are recalls on this. My mechanic says he sees this VERY frequently.
2) Is this a potential do-it-yourself? I'm handy with tools but not a mechanic.
Thanks!!
Old 11-07-2005, 11:57 PM
caravandrvr's Avatar
caravandrvr caravandrvr is offline
Re: Power Steering leak-Help Needed
Most of the time I see that it is simply the hose and not actually the resevior itself. Worth a closer inspection IMHO...
Old 11-09-2005, 08:41 PM
It's definitely the resevior. I can see where it is seeping through the metal casing after I wipe it off. Wish it was just the hose!
Old 11-09-2005, 11:13 PM
waltham41 waltham41 is offline
Is it in an area where you could siphon out part of the fluid, clean the spot with something like carb cleaner and fix the hole with quick set JB weld? I have fixed a lot of things with that stuff over the years and it lasts a long time if done properly.
Old 11-10-2005, 09:08 AM
Good call, waltham41, I've had many a miricle repair using JB Weld! If it isn't where there is any high pressure it just might work....
Old 11-10-2005, 09:37 AM
He says the leak is in the reservoir, that would be a perfect place for good ole' JB
Old 11-29-2005, 08:31 PM
Mitchie Mitchie is offline
Re: Re: Power Steering leak-Help Needed
I had to fix mine on the weekend, I removed the pump from underneath and braised it. Seems fine now.
Old 11-29-2005, 09:16 PM
vipergg vipergg is offline
Thanks!!
Yup had the same happen on my 96 , they use cheap thin metal on these and in high salt ares these tend to rust thru , seems to me it was between 2 and 300 dollars to have the dealer do it .
Old 11-30-2005, 06:17 PM
I had thought about using JB weld but I couldn't get the resevior completely drained and it kept seeping through. I found JB putty and decided to give it a try. Took 3 attempts of cleaning it with specs cleaner, holding my finger over the leak while it dried, then slapping on the putty and holding it for 10 minutes. 3rd time it finally stuck to the metal instead of my hand. It seems to be holding for the time being.
Removing the resevior looked to be a real pain.
Thanks for all the advise!!
Old 04-09-2006, 12:14 AM
tvrepair007 tvrepair007 is offline
Removing the resevoir is a HUGE pain. But can be done. Getting the pulley off of the old one is a whole other ball of wax. My pulley was so rusted on that the pulley removal tool just broke the pulley!
This JB weld thing sounds like it's worth a shot.
Old 04-09-2006, 07:50 AM
More advice for Caravan owners , also keep an eye on your oil pan , eventually that will rust thru too if you live in high salt areas.
