windshield wipers inop.
My w/shield wipers quit working and I checked the fuse which is ok. Before I order a new motor is there anything else I should check?
thanks. moif |
Re: windshield wipers inop.
Getting power to the wiper motor? Switch good?
Thanks for your help. I now find the wipers are working intermitently. I`ll try to clean it up as you did. It`s a `87`classic brougham LS with just 57k on it.
Can only find one site that has the motor and I`m not sure it`s the right one. Thanks again. moif |
If its a 91-96 then its probably your wiper pulse module. Its connected to the wiper motor. You can take the cover off of it, and the circuit board will usually be corroded, or burnt if its bad. Not too cheap though.
91 Caprice 305 700R4 2.56 225/70R15 |
Just after my last post I noticed there was a clicking sound from the motor so I moved the power connection that goes into the motor and the wipers started working. They are working steady now so I guess I`ll wait and see.
Thanks for all the help. moif |
Its sounds like the contacts that the wires connect to are corroded or dirty, unplug thr wiper motor, and clean the contacts with some sandpaper or a wire brush and see what happens.
Contacts cleaned and contacts are contacting. Wipers operational.
And I almost bought a new motor. This forum works! moif |
