Old 03-22-2006, 01:10 AM   #1
Bravada 97
Bravada 97's Avatar
Front Door Panel Removal on 97'
Hi guys. I am trying to remove the inside door panel on my 97 Bravada so that I can replace my factory speakers. I have gotten the panel with the electric window/door switches out and popped out the bottom and sides of the panel but can't seem to get it any further. After I have popped out the bottom and side do I lift straight up to remove it completely? Also how do I get the section off around the door handle?
Lastly is there a separate procedure for the rear door panel as I want to tackle those speakers next?
Thanks for any info,
Bravada 97 is offline   Reply With Quote
Old 03-22-2006, 10:38 AM   #2
Eslhockey92g
Eslhockey92g's Avatar
Re: Front Door Panel Removal on 97'
where the door handle is to close the door. the little dish there. theres a plastic plate u have to pop off and than there are 2 bolts right there. I forget the size but there small like an 8 MM. once u take those bolts out and your window and lock assmbly off. the pannel just pops of and slides up. should be the same for the rears also
good luck
Eslhockey92g is offline   Reply With Quote
