Old 03-22-2006, 10:23 AM   #1
DaveLance
DaveLance's Avatar
Brake pad question
About a year and a half ago I did a full front brake replacement (pads, rotors, calipers, fluid bleed). This past weekend I removed the tires to lube the suspension and clean the brakes and I noticed that the outer brake pads are worn down much more (about twice) than the inner pads. Since everything was replaced at the same time, shouldn't the pads be worn evenly?
DaveLance is offline   Reply With Quote
Old 03-22-2006, 11:26 AM   #2
muzzy1maniac
muzzy1maniac's Avatar
Re: Brake pad question
We're the guide pins every greased? It sounds like the pins got stuck an kept the pads in contact with the rotor.
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
muzzy1maniac is offline   Reply With Quote
Old 03-22-2006, 11:14 PM   #3
DaveLance
DaveLance's Avatar
After some more research, that's more than likely the case. Thanks for the reply.
Old 03-22-2006, 11:19 PM   #4
old_master
Advisor/Moderator
old_master's Avatar
If the caliper hardware was not replaced and lubed, that's your problem. All hardware should be replaced with every brake job for that very reason.
Inboard pad wears faster = caliper piston is not retracting properly after releasing brakes.
Outboard pad wears faster = caliper hardware is binding after releasing brakes.
old_master is offline   Reply With Quote
Old 03-23-2006, 12:26 PM   #5
BlazerLT
AF -Advisor
BlazerLT's Avatar
Did you do the work or did a shop do it?
If a shop did it they are responsaible for fixing it.
BlazerLT is offline   Reply With Quote
Old 03-23-2006, 12:36 PM   #6
DaveLance
DaveLance's Avatar
I did all the work myself. Since the calipers were completely new, I just figured that all the hardware was lubricated. Perhaps the guide pins just dried out after awhile.
Old 03-23-2006, 12:55 PM   #7
BlazerLT
AF -Advisor
BlazerLT's Avatar
NAh, you have to lube them before installing them.
You are best off lubing them up and installing a whole new set of pads.
Old 03-23-2006, 02:16 PM   #8
DaveLance
DaveLance's Avatar
Yep, was planning on it, thanks.
Old 03-23-2006, 04:18 PM   #9
muzzy1maniac
Being in the snow belt of NY(well no snow this year anyway lol!) every brake job I've done has at least one pin stuck! I've found using a good synthetic high temp grease works best. Lube the snot out of them and make shure the boots are in good shape and on correctly.
2004 Explorer XLT
4.0L 4x4
4x2 3.0L
Old 03-24-2006, 01:38 AM   #10
BlazerLT
AF -Advisor
BlazerLT's Avatar
Good advice, synthetic is less prone to heat failure.
