Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 03-17-2006, 03:55 PM
sluggo996 sluggo996 is offline
newbie- question re: bomz short ram
I have a 98 1.6 base model sentra, I read the sticky post, good stuff, very helpful. I just bought a Bomz short ram intake, and I can make it fit... mostly. Anyone done this? The hose fittings seem off, but I can fix that. I'm wondering about the sensor that fits in just back of the airbox, tho. Any suggestions/ words of wisdom? TIA
vinny
Old 03-17-2006, 05:20 PM
fugiot's Avatar
fugiot fugiot is offline
Send a message via MSN to fugiot
Re: newbie- question re: bomz short ram
Are you talking about the MAF? or the smaller sensor inside the airbox?
If it's the MAF, it's should be directly in the tubing behind the filter.
The smaller sensor....eggh, I hate that thing. Just try to stick it into the filter somehow. It needs a bit of air or something. Not too sure, but it's a little pain in the ass sensor.
SR20 powered SE-R: 60mph-6.2 sec., 1/4mi.-14.7 sec.
VG30 powered Maxima SE: 60mph-7.8, 1/4mi.-15.8 sec.
Don't make me ANGRY
Or I will kick you in teh NUTS
Your NUTS will feel teh steel toe
Teh steel toe that has been in teh snow
I will rip off yuor pants and kick yuo in teh nuts
My steel toe will stick to yuor nuts
And I will swing yuo around by yuor nuts as I do a Hurricane kick
Old 03-17-2006, 05:56 PM
Thanks fugiot.
That's right, it's the MAF. So what I was wondering is where should it go w/ the new piping? Pretty much the system is just an s-pipe made of aluminum, some hose (wrong size for application), a square mount & boot for the filter, some brackets and a boot for the throttle body, nowhere to put the MAF. Should I retain that section of the old to keep the MAF in place?
Old 03-17-2006, 11:04 PM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
if the 's' metal piping fits from your throttle body to where the air filter should go, im sure you could drill out a hole the size needed to put the MAF sensor in it.....
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 03-18-2006, 10:07 AM
Thanks Chiquae07, it looks like I can use the entire MAF body in between the s-pipe and the filter - it might have even been designed that way. Great forum here, I'm sure I'll be back when I do the suspension.
Old 03-18-2006, 04:00 PM
fugiot's Avatar
Yeah, I was about to say, the entire MAF assembly connects to the rear of the filter and then the tubing connects to the rear of the MAF assembly.
Don't make me ANGRY
Old 03-18-2006, 05:23 PM
Thanks for the advice, the system is in. It was a less than straightforward install, had to buy a step-down boot at Home Depot to make it work, and the backing plate did not fit onto the MAF unit without modification. The sound is good, when you open the throttle wide, other wise no noticable difference. Same with performance, you feel it up top, but nothing at low revs. Thanks again.
Old 03-18-2006, 07:11 PM
slideways...'s Avatar
slideways... slideways... is offline
sorry im late but it sounds like the sensor your talking about is the air intake temp sensor. a little two prong thing that plugs into the airbox or the tube coming from the bumper to the box. i have always kept that plugged in and just left it taped or tied to something. seems to work fine. too bad intakes dont come with a provision for that, it seems like it would be a no duh thing to just add a connection to the end of the filter or something.
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 03-19-2006, 08:46 PM
fugiot's Avatar
Yeah, I've heard the best use for the temp sensor is to punch a teeny hole in the filter itself and let it get some of the air. Or if you have an HKS filter, just push it thru the filter meshing.
Don't make me ANGRY
Old 03-20-2006, 07:43 AM
I left the sensor that fits into the old intake tube alone - left the tube in there as well, w/o the airbox. I'm getting a "juicebox" that's supposed to fit onto the air sensor clip - should be in very soon, but I'll be out of commision for awhile (back surgery). Talk to you all later
