Old 07-07-2002, 12:13 PM   #1
88civic
Motor Mounts
I have been thinking of maybe doing a b16a1 but the motor moounts are way to much. Does anyone know where i can get some for pretty cheap or at a good price. also what year and type of tranny will i need.
88civic is offline   Reply With Quote
Old 07-07-2002, 07:21 PM   #2
Jmunk
Send a message via AIM to Jmunk
Mounts
If you have a welder and you decent at welding than make your own. I made some for my friend when we put a B18a into his 88 CRX. It wasn't hard at all. The only mount that needs to be changed reall is the passenger side mount. The drivers side fits good but you need to use spacers on the bolts that attach to the motor to lower the motor like 1/4 inch to clear the hood. The back mount you need to unbolt and rebolt it in holes that are already drilled in the rear crossmember from the factory. Than all i did was got things straight and level and tacked the tranny mount in place and pulled it out and put steel around the gaps and welded it all up and painted it black. We didn't put a front mount in b/c it's not essential but it wouldn't hurt, all we did was grind it out. We also put the energy suspension motor mount bushings in the rear mount to help keep things steady.
Jmunk is offline   Reply With Quote
Metro Auto Trans Mount FUBAR ManicMetro Metro 1 01-11-2010 10:15 PM
Pass Motor Mount Plate - Stuck... pyro4329 2nd Gen 00-05 1 11-08-2009 04:22 AM
Z24 Motor Not Mounting To Motor Mounts Same Type Engine As Previous capnsquarters140 Older Pickups 2 02-12-2007 09:51 PM
motor mounts, tranny mount casinonut531 Grand Prix 2 05-03-2004 07:51 PM
motor mount - torque mount????? maxspeedhonda Engineering/Technical 4 03-09-2003 02:37 PM
