Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 03-09-2006, 12:51 AM
stevefx19 stevefx19 is offline
Send a message via Yahoo to stevefx19
brake troubles
I just bought a 90 Dakota off of my buddy. All of the brake lines need to be replaced because they are really rusty. I have disconnected all of them except for the one in the back. There is a steel line that connects to a rubber hose, I accidentally snapped the steel line and the fitting is stripped so I cannot disconnect it from the hose I tried everything (Plus it is really rusty and I've even tried penetrating fluid). Is there anyway to disconnect the rubber hose at the other end where it hooks into the tee on the axle or does that tee come off the axle somehow? I'm trying to hurry this up cuz I need the truck to move so any help would be greatly appreciated Thanks.
Old 03-10-2006, 08:49 PM
Gizmokid2005 Gizmokid2005 is offline
Send a message via AIM to Gizmokid2005 Send a message via MSN to Gizmokid2005 Send a message via Yahoo to Gizmokid2005
Re: brake troubles
No, you DON'T wanna mess with any seals. Brake lines have an enormous amount of pressure when the brakes are applied, that's why almost all of the lines are metal. You are going to have to keep working on that connection or go after a new rubber hose section.
I'm not sure what hose you are talking bout in the back, I know they have them in the front, I had to redo my front ones...NEW....I'm sorry there isn't another way. Brakes suck.
Old 03-12-2006, 01:32 AM
Stevo2's Avatar
Stevo2 Stevo2 is offline
Re: brake troubles
The hose is one piece with the tee. You have to remove the 2 steel lines that go into the tee and then the tee should be held on the axle with a vent(pipe) or a bolt. You'll need to pick up a new rear hose.
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
