Go Back   Automotive Forums Car Chat > Pontiac > Grand AM
Old 02-24-2006, 02:24 PM
AspDotNetGuy AspDotNetGuy is offline
Is this scanner okay for my 1995 Grand Am
So i was going to take my car in to get scanend. As I am having trouble.
But I can get this scanner for $40.00, and it costs 37.00 to have it scanned.
Will this work:
http://www.canadiantire.ca/assortmen...=1140812181047
Old 02-24-2006, 06:06 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Is this scanner okay for my 1995 Grand Am
The link doesn't work for me but make sure your car is OBD II before you buy an OBD II scanner. If it is OBD I then you can cross connect two pins and read the codes on the check engine light. Some 1995 cars have OBD I and some are OBD II.
Old 02-24-2006, 07:18 PM
How do i check and how do i cross connect?
Old 02-24-2006, 11:15 PM
vamc's Avatar
vamc vamc is offline
I looked at it, it should work!
Old 02-25-2006, 12:10 AM
Argghh I went and bought it this afternoon and it the manual says it works upto 1993 Pontiacs? So OBD ii started in 1996 and this thing only works on 1993 and older what the heck works on a 1995?
Old 02-25-2006, 03:40 PM
xonelith's Avatar
xonelith xonelith is offline
Send a message via MSN to xonelith
My understanding of the GA's is the 1996 + are OBDII and your's should be OBDI. Check with your dealership. Either they use the Tech I or the Tech II to scan your car.
Did you try to connect the unit and read the codes? If all else fails, take it back. Crappy tire is good for that..LOL
All Motor 2001 GA GT1
Milzy Motorsports
HPTuners
GrandsOntario
