Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-08-2006, 03:49 AM
jonnyboy9012's Avatar
jonnyboy9012 jonnyboy9012 is offline
Send a message via AIM to jonnyboy9012
Turbocharger waterlines???
Im kinda new to forced induction, of always known about it and am just getting into doing it. I need to know if all turbochargers require the use of water cooling lines. Im looking into getting a t3/t04e turbo to put into a chrysler. Thanks for your help?.
Current Cars and Specs:
1972 chevrolet nova
402 Chevy Big Block
Borg Warner 5 speed trans.
Future Mods:
Procharger super charger
NOS Carb Plate Nitrous System (150 Shot)
Hoosier pro street radials
2005 Chrysler PT Cruiser 2.4 Liter (soon to be traded for 96 TSI AWD)
Garret T04-E Turbo
"Quick Flow" Air Filter
Complete Custom Setup
6psi@219whp
URC Member #1
Old 07-08-2006, 10:28 AM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: Turbocharger waterlines???
T3/T4's dont' have coolant lines (although i'm sure there is an exception). Most turbos that have coolant passages are ballbearing or huge. Also i think there are a handful of factory turbos like 14b's that are water cooled as well. You don't have to water cool the turbo if it is that big of a hassle, but it is designed to give the turbo as much life as possible.
T3/T04's like mine don't have water ports...
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 07-08-2006, 07:52 PM
UncleBob UncleBob is offline
AF -Advisor
most turbo's off stock cars have water cooling, (modern engines, ie, last 15+ years).
non-car model specific turbo's often don't have water cooling. But whether the turbo you find/like has the option or not, you don't have to use it.
Its mainly to prevent coking, which is mostly a concern in the long term, ie, 100K miles. I always leave the water cooling out with my systems, but then how much heat saturation the turbo system has to deal with is another large factor...my systems rarely have a problem with it
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 07-09-2006, 02:28 AM
Thank you very much for your help... i was very confused. By the way i like Schister 66's signature, 10 psi of boost and a stock bottom end, very nice. I plan on running a t3/to4e on a 2.4 liter chrysler motor, probobaly around 8 pounds at max, maybe 10 if i get brave. I know you are thinking that its a damn pt cruiser that im putting it into and thats its a grandmas car, but it'll be one hell of a sleeper. Thanks alot.
1972 chevrolet nova
402 Chevy Big Block
Future Mods:
Garret T04-E Turbo
6psi@219whp
URC Member #1
Old 07-09-2006, 02:33 AM
AF -Advisor
I'd turbo my lawn mower if I won the lottery and had the time and money to kill.
There is no such thing as a bad engine to turbo. I personally find the truly out-of-the-norm custom built turbo systems the most interesting. I like to see some germ of originality. Sure you could pick up a honda civic and turbo it.....just like every fricken body. Woopie
but....there isn't much room in the engine compartment in the PT's.....just did a timing belt on one couple days ago. Talk about a royal pain in the ass. Couldn't imagine what it'll be like working on one with a turbo on it. I'd definitely spend a lot of time engineering it so it is at least easy to remove to get to the rest of the engine without too much added effort...
Old 07-09-2006, 04:31 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Was there a factory Turbo option for the PT cruizer in the states?
We had one here for a little while, but it was in the RHD version, which I think was assembled in Europe?
Old 07-10-2006, 08:38 AM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
i've seen it done a few times, totally pointless but damn cool.
Seatbelts Saved My Life
Old 07-10-2006, 06:22 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Yeah, it was the SRT-4 setup but it was restricted to 180HP.
