Old 02-06-2006, 01:25 PM   #1
Ramblin Fever
FS - 265/75 R16 Yokohama Geolander AT II
only have 5k miles on them.
Tires are great, nothing wrong with them; they are the LT265's with 16/32 tread depth. Rotated only once so far.
These tires look great on the Rodeo, the only reason they are for sale is I also pull a heavy boat with this Rodeo and I didn't realize til the weekend just how much bigger these tires are over the 245/75's I use to run.
I had to move the boat around the other day, and the truck was struggling WAY more then I like. So, unfortunately they've got to go, my boat was here first
If you don't haul a load, this size tire is fine for the 3.2L Sohc, I've had no issues or complaints about the power with just the truck. But, if you're gonna tow more then 3k#, these will not work.
Asking $350, OBO, buyer pays shipping
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Ramblin Fever is offline   Reply With Quote
Old 02-06-2006, 01:37 PM   #2
tomlcollins
Re: FS - 265/75 R16 Yokohama Geolander AT II
Where do you live? I'm wondering how much shipping would be to Charleston, SC.
02' Rodeo
tomlcollins is offline   Reply With Quote
Old 02-06-2006, 02:27 PM   #3
directory
directory's Avatar
geesh, you and that boat!
it's all about your boat, isn't it...
99 passport 3.2L v6 DOHC auto-trans 4x4 modified IFS 10 bolt front/ dana 44 4.10 rear
SKYWARN
we be clubbin'
--B
directory is offline   Reply With Quote
Old 02-06-2006, 06:34 PM   #4
rodeo02
I'm prolly way off base , but wouldn't a slightly larger diameter tire enhance towing power?!? Doesn't the bigger diameter tire result in a 'lower gearing' effect like higher RPM's at hywy speeds??
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
rodeo02 is offline   Reply With Quote
Old 02-06-2006, 07:53 PM   #5
Ramblin Fever
You know you could be on to something that I hadn't thought about.
I have a plan that I should've thought of before posting this thread - here's the scoop, tell me what you think.
Last Spark plug change came about 80k miles ago - Bosch Double platinum
We pulled 1 about 20k miles ago, and it was still good and clean, box said they were good for 100k.
However, I'm changing them out VERY soon, like in the next month.
Other question is, I only recall 1 time ever of having to change one of the coil packs; all others are original = 150k miles
Que me in on what all I should do in regards to whether or not coils packs, wires, etc need changed along with spark plugs.
Fuel filter is only 15k old; and next month it's getting a tranny & radiator flush along with new plugs.
Problem - truck has lost a bit of zip, seems to struggle at times to maintain speed.
No CEL is on anymore, fuel pump IS original (don't know if that plays a part); have only always used a paper filter, in which I've never had to clean the MAF (IIRC) sensor??
For a while, I was playing around with a CEL code of P0401 (insufficient EGR flow), cleaned EGR twice, dumped a bottle & a half of Techron fuel cleaner in about 400 miles ago, CEL went off shortly thereafter and has not returned.
Need input on ideas??
1997 3.2L V6 Rodeo
