Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 11-04-2005, 08:01 PM
Laura Tanner Laura Tanner is offline
rattling sound when accelerating
I have a 2003 VW Jetta, 1.8 Turbo. All of a sudden, there is a rattling noise (from the engine I think) whenever I accelerate. It's especially noticeable going uphill. Any ideas of what the problem might be?
Thank you
Old 11-04-2005, 10:54 PM
ctuagent117 ctuagent117 is offline
maybe spark plugs. have you changed them yet? or maybe timing belt. sounds like you need a tune up. could be engine or turbo mount. id start off with a tune up.
Old 11-04-2005, 10:55 PM
you didnt say how many miles u have
Old 11-05-2005, 11:53 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
check the exhaust system. there is a mount right after the cat. that normally breaks and causes annoying rattles
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 11-05-2005, 11:59 AM
Talking Re: rattling sound when accelerating
The car has 31,000 miles. About a month ago, it got a 30,000 mile service. I don't know if they changed plugs then.
Old 11-05-2005, 12:02 PM
If it were the exhaust system, would you expect the rattle to be worse upon acceleration?
Old 11-06-2005, 10:16 PM
Re: Re: rattling sound when accelerating
yes, it would be worse uphill. its too early for timing belt or sparkplugs. wouldn't hurt to get the exhaust pipes checked out. nice diagnosis V-dub
Old 11-17-2005, 10:58 AM
Good call! Here's what the VW dealer said: Bolts for the exhaust manifold to the turbo loose, and the gasket was worn. Rethreaded the hole in the bracket holding the intake pipe and secured.
Thank you!
Old 01-30-2006, 10:44 AM
shaz_mtl shaz_mtl is offline
Hi, I have a 97 Trek with the same problem. The dealer in Montreal told me it was a loose heat shield making that noise. I'm poing to have it fastened more securely this week-end and will let you know if the noise stops. He said to remove the shield would cause the wires to melt eventually so that's obviously not an option.
