Old 01-22-2006, 10:59 AM
cham2020's Avatar
cham2020 cham2020 is offline
Send a message via ICQ to cham2020 Send a message via MSN to cham2020 Send a message via Yahoo to cham2020
Honda Civic SIR EK4
By Fujimi
Color: Medium Yellow
Evo Rocks !
Old 01-22-2006, 04:48 PM
digitalbanzai's Avatar
digitalbanzai digitalbanzai is offline
Re: Honda Civic SIR EK4
Gee how do you get so many kits?
Old 01-22-2006, 05:34 PM
kaho's Avatar
kaho kaho is offline
Yea man, the time it takes me to build one model and you seems to have built 20+ ~!!
Old 01-22-2006, 07:59 PM
cham2020's Avatar
i stock up about 8 kits in the past and i didn't build them due my exams
so i build them now
kaho
it's only my 5th kit
Evo Rocks !
Old 01-23-2006, 12:32 AM
mrsmith1016 mrsmith1016 is offline
i love EK!!!!!!
but y don't remove the side trim???
my garage...
http://www.wretch.cc/album/mrsmith1016
Old 01-23-2006, 12:39 AM
cham2020's Avatar
i am building it stock ler mr smith
Evo Rocks !
Old 01-23-2006, 01:29 AM
sportracer02's Avatar
Hi,
colour finish looks like on your Mustang. Do you cover it with clear or will you polish it out?
Micha
Old 01-23-2006, 01:51 AM
cham2020's Avatar
i just sprayed a few coats LAst night. i just sprayed a few more coats just now and it lopoks much glossier...yeah i will polish instead of clear coat...
here is wat it looks like
Evo Rocks !
Old 01-23-2006, 02:41 AM
Yellow is a hard colour do bring to a body. Around the doors it looks quite dark, the yellow didnīt cover the base quite well. What colour was the base coat or - if covering the plastic directly- what was the colour of the body?
Micha
Old 01-23-2006, 02:48 AM
cham2020's Avatar
the original color body is dark silver and i give it a light color grey primer
Evo Rocks !
Old 01-23-2006, 03:44 AM
KTem's Avatar
KTem KTem is offline
Yeh, Tamiya's yellow tends to draw away from the panel lines... You should try painting them using very light mist coats, so the paint doesn't have the chance to run.
Keep it up!
Old 01-23-2006, 08:14 AM
cham2020's Avatar
KTEM
i am not using tamiya spray cans. i am using normal acrylic can spray.
Evo Rocks !
Old 01-23-2006, 09:13 AM
KTem's Avatar
I guess the same goes for the paint you use!
Old 01-23-2006, 09:43 AM
cham2020's Avatar
maybe that's why you guys say yellow is a hard color ?
Evo Rocks !
Old 01-23-2006, 10:08 AM
Apexi_N1 Apexi_N1 is offline
Your EK is looking good!! Any plans? or box stock?
Indeed. yellow doesn't not cover ANYTHING!
I make the mistake on my yellow EK as I sanded some of the white primer off before I spray the yellow. Those part where the primer was off, the silver shown clear after 2 layers of yellow. In the end, I have to stripe off all the paint and start from ground 0
