Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 01-17-2006, 11:23 PM   #1
smokey108842
Need some tech help!!!!!!!
Hi I have a 97 Neon sport 2.0 dohc. I believe the head gasket blew because i was refilling radiator fluid at least 3 times a day and then it just quit running. It has by far been my favorite car and I don't want to get rid of it and I like doing everything myself. Would I just have to change the head gasket or is something else wrong too? What else should I do while I have to motor apart?
smokey108842 is offline   Reply With Quote
Old 01-18-2006, 08:50 AM   #2
das2123
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Need some tech help!!!!!!!
If you have a blown HG, then you should see oil in your coolant or coolant in your oil. If you were putting in that much coolant, then you may have had a bad coolant leak. Check and inspect all your hoses. Did your temp gauge ever hit the H mark? You may have overheated your engine.
das2123 is offline   Reply With Quote
