Old 12-26-2005, 06:54 PM
userpete1037 userpete1037 is offline
Hoses
I have a 95 Chevy 1500(2WD). Can someone tell me a easy way to flush the hose that runs from the heater core to the water pump. The problem that I'm experiencing is that I have to let my truck warm-up for quite some time for it to get hot because if I don't, it will be cold. The waterp pump is new which leads me to believe the hose is clogged up.
Old 12-26-2005, 07:36 PM
Floyd_ODB Floyd_ODB is offline
Re: Hoses
sound more like you have a thermostat that opens to soon. maybe a weak spring or the wrong temp.
however I have put the input hose to the heater core and put it on the output side of the heater core (left the other side off. fired it up, reved the piss out of it to back flush the core. its doubtful that the hose is clogged. an new hose wont cost but $10. some nipples (water pump/intake) are restricted slowing the coolant through the core. flow to fast wont allow good heat transfer.
Old 12-26-2005, 07:39 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Hoses
Is the engine warming up to 195 degrees good and fast?
If so it would be more the heater core than the hose.
Does both heater hoses get hot to the feel?
MT
MT
Old 12-26-2005, 08:20 PM
Re: Re: Hoses
The heater core was replaced about a month ago. Today for some reason, the hose running from the water pump became real hot like the other one. The only thing is if I let it sit overnight, It may take a long time before it gets real hot again. The thermostat was replaced and the coolant system was flushed as well.
MT
Old 12-29-2005, 12:00 AM
Okay I've noticed that when the weather is warm, the hose running from the core to water pump gets hot to the point where u can't grab it. When the weather is cold overnight, it take forever to get slightly warm. Why is this? Has anyone had this problem? Could the hose be bad?
Old 12-29-2005, 10:10 AM
MT-2500's Avatar
AF - Advisor
Re: Hoses
Check the engine running tempt/thermostst.
Even a new thermostat can be bad.
Get the engine tempt up there to where it should be and go from there..
MT
MT
Old 12-29-2005, 03:47 PM
I have a lil seapage from the thermostat housing. Would this have any effect on it? It's a pain trying to get that thing to seal up completely.
Old 12-29-2005, 05:28 PM
MT-2500's Avatar
AF - Advisor
Re: Hoses
The thermostat works or it does not work.
Check THE ENGINE RUNNING TEMPTURE.
MT
MT
Old 12-29-2005, 10:39 PM
i can guarantee u it's not 190/195. Oh, just realized that my thermostat is a 180. I guess this may have something to do with it.
Old 12-29-2005, 10:49 PM
MT-2500's Avatar
AF - Advisor
Re: Hoses
If you want heat when it is 20 below 0 and want your engine to live to a ripe old age.
PUT A 195 THERMOSTAT IN IT.
Let us know how it does.
MT
MT
Old 12-30-2005, 12:21 AM
Re: Re: Hoses
I'll take your advice and do it. Will let you know the result. Thx
MT
Old 01-01-2006, 08:30 PM
Well MT-2500,
Looks like you were right. Put the 195 in and whoa!!!!!!!!!!!!!! Heat to da bone........Thx bro.
Old 01-01-2006, 09:30 PM
MT-2500's Avatar
AF - Advisor
Re: Hoses
Thanks for posting back and letting us know how it went.
And glad you got heat.
MT
MT
Old 01-22-2006, 11:43 PM
Re: Hoses
It's been a while but my hunch was right about the hose that runs from the core to water pump. It was bad and I replaced it. Now you can't even hold it to the touch when engine warms up.
Old 01-23-2006, 12:16 AM
Crasen Crasen is offline
Re: Hoses
So did the thermistat or the heater hose seem to increase your heater temperature more? Well thanks for letting us know what fixed your trucks heater.
