Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Off-Topic
Old 01-05-2006, 05:36 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
94 turbo engine and tranny
what mods have to be considered installing a gst motor in my talon... from a 94, besides mounts, wireing, tranny, dash.... motor mounts? a friend has one that he might be selling ,me... it comes with a tranny too 5 speed
Old 01-05-2006, 05:45 PM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: 94 turbo engine and tranny
I don't even think your mounts are different. You are essentially putting the same motor into your talon that was in there before +a turbo.
So you will probably need an ECU from a GST or TSI, and maybe a turbo wiring harness. Other than that I think everything bolts right up.
1991 GSX 2.3 Stroker
Old 01-05-2006, 06:17 PM
EDMUND65's Avatar
SWEET! what shuould i look for on this motor when im gunna buy it? i dont know price yet... but i think it has 50 or less K miles on it...
Old 01-05-2006, 06:24 PM
defiancy's Avatar
Re: Re: 94 turbo engine and tranny
If it's already out.
Look for any cracks in the block or heads, any place that is leaking oil excessively.
Before you put it into your new car I would advise taking it apart and replacing all the seals for the heads, valve cover and what not.
Check to make sure all the sensors are good.
Also might be a good time to replace all the lifters, and you can get some better oil squirters if you want.
This is also a good time to change cam gears or do any upgrades to the engine itself.
Old 01-05-2006, 07:09 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Definately do a compression test if at all possible. I wish we would have done that on Mikes car, we would have been able to get it for lots cheaper. I think whoever post above was right, a 4g63nt and a 4g63t uses the same engine mounts and I would assume the harness, but you might need one of those. I think all you would need is the ECU. Is the fuel pump in the NT going to be able to keep up with a turbo engine?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-05-2006, 08:00 PM
defiancy's Avatar
I think the fuel pump is the same in the NT as in the turbo, I know the injectors in the car are different.
But I'm not 100% sure in this case.
Hell it could use a walboro 190 anyway
Old 01-06-2006, 12:42 AM
EDMUND65's Avatar
dduude 100$ and the interrior from my parts car and the turbo engine and tranny wirein g harness and ecu with 32k miles is mine!!!
Old 01-11-2006, 02:15 PM
subsrmything subsrmything is offline
i have a 1996 eclipse
i put two turbos in it
changed the suspension
and it flys
Old 01-11-2006, 05:53 PM
clarky99_69 clarky99_69 is offline
Change your fuel pump put in a better pump, this should have all the info you need to make an N/T into a turbo http://www.vfaq.com/FAQlocator-index.html
Old 01-11-2006, 10:08 PM
Thor06's Avatar
Jizzed In My Pants
and it flys
And that has what to do with the topic at hand?
EDMUND you BASTARD!!! That is one hell of a deal man, fuck you.
Old 01-11-2006, 10:29 PM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
and it flys
Two turbos? I call bs. LIAR!!
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 01-11-2006, 11:23 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Re: Re: 94 turbo engine and tranny
It's possible if its a sequential turbo setup...
But I doubt he has it. Let's see some pictures to back it up, subsrmything...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
