Old 01-02-2006, 04:35 PM
Jeff117 Jeff117 is offline
Remote starter kills engine
I installed a remote car starter this weekend. Initially everything appeared fne. I concealed the wires and reassembled the dash. Then the truck would not start either by the remote or the key.
It would turn over but not run. I removed the power lead to the remote and it started using the key. While the engine was running with the key, I plugged the unit back in and it killed the engine. Same scenerio when I stop the engine and plug the power lead back in. Both the remote and the key do not work.
Any ideas???
Old 01-05-2006, 10:04 AM
jveik jveik is offline
Re: Remote starter kills engine
maybe you are shorting out the power to your ignition/distributor cap or whatever. try plugging it in and seeing if you are getting spark or not. this can be simply done with a timing light. put it on one of the plug wires and if it blinks then you are getting spark, and if nothing at all, then no spark.
Old 01-06-2006, 12:36 AM
whalerboy's Avatar
whalerboy whalerboy is offline
What year truck? What brand starter? A good site to check to see if you've connected everything to the proper wires is....
http://www.the12volt.com
They have alot of info laid out there as the which wires you need, and where to find them. Was this a starter/alarm combo that uses a starter interupt as a security feature?
Old 01-06-2006, 01:58 AM
raycorri raycorri is offline
Any ideas???
Not sure what year you have. This TSB might help.
http://www.gmupfitter.com/publicat/bull/bull26.pdf
Ray
