want to make my rear go lower!..need help
hey i have a 96 bagged ranger.. the front completly lays out.howveer.. the rear goes pretty low.. but not as low as i want it to go. i wanna be able to drag. when i sit the hole back end down.. its not even rubbing the wheel well. what could i do to make it go lower?
Ryan |
Re: want to make my rear go lower!..need help
change leaf spring shakles to ones that will seat the rear end lower, change leaf springs to ones with a lower profile (less arc) or you could go whole hog and customize your frame, but thats a big big job. Some rangers come with a highrider package and the rear leaf springs may be seated on a 3-4 inch lift block... if that is the case you can remove that also.
Life is a work in progress... |
you can only go so low before your rear diff will hit the underside of the bed. then you will have to cut a hole
Mudder is right. You will probably have to notch the frame to get it to pancake.
