Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 11-25-2005, 10:03 PM
jonjarash jonjarash is offline
Bad Coil again??
Hi,
I have a 98 with 110k miles. Last January I had the no. 3 and 8 coil replace (check engine). The car ran like crap...so that fixed it. Eight months later it did the same thing, so I had the remaining 6 coils replaced.... so that I did not have to deal with the same problem for awhile or so I thought. A week ago the no. 3 went again, I took it back to the mechanic and he replaced it. A couple of days later check engine came on again and now its running worst than ever before. When its on idle and when I accelerate it misses. Its like I'm driving a 3 cylinder car. I can't keep replacing these coils as they are not cheap. Obviously something else is making them go bad, but what is it, I don't know. Pls. help.
Oh and Happy Thanksgiving!
Old 11-26-2005, 12:09 PM
Anybody pls. help.
Old 11-28-2005, 09:29 AM
bearcat329 bearcat329 is offline
Re: Bad Coil again??
sounds like maybe the coil seals may be bad, and water is getting in there, causing them to short out, have your mechanic check for that
hth, Rick, Ore
Old 11-28-2005, 11:03 AM
Re: Re: Bad Coil again??
hth, Rick, Ore
Do you have a picture of the seal you're talking about? Anybody?
Thanks for responding.
Old 12-14-2005, 10:06 AM
grogden grogden is offline
Re: Re: Re: Bad Coil again??
the boots over the spark plug leak and water will short the coils,check if you have any coolant leaks that might drip down
