Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-11-2005, 06:48 PM
Powersurge Powersurge is offline
what do i need to turbo?
I have a 95 talon ESi with a 5 speed. i recently rebuilt the motor, bored it over .20 and put in better rods with flattops, a 3 angle valve job, a better cam, and some other things. i want more power, so im gonna boost it instead of spraying NOS through. I need to know what parts i need to scavange up to do this, Im gonna put my own kit together instead of buying one, i dont have the $1200 to do that. any help would be appreciated. also, id like to know what size turbo would be the best for this application. thanks
Old 12-11-2005, 06:55 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Read the FAQ and search this site, you will find all the information you need. This has been heavily covered.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 12-12-2005, 10:49 AM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
what kind of compression you have now? because with that cam and whatever else you changed it might need higher then pump gas to run properly with some low but noticable boost.
