Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-17-2005, 05:47 PM
amen49 amen49 is offline
Unhappy burning oil
Hi Guys:
I have a 2001 Impala with 53K on it. I have been fairly happy with the vehicle except that I keep burning oil. I use a quart every change or about 3K miles. I have built engines and never had one that was put together right burn oil. one went 270K before the body gave out and still not burning oil. I change oil and filter every 3K.
Chevy is tellling me that a quart at a 2k is normal. Any ideas.
Andy
Old 11-17-2005, 05:56 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: burning oil
Originally Posted by amen49
Hi Guys:
Andy
Information on Engine Oil Consumption Guidelines
All 1998-2006 Passenger Cars and Gasoline Powered Light Duty Trucks Under 8500 LB GVW
The accepted rate of oil consumption for engines used in the vehicles referenced is 0.946 liter (1 qt) in 3200 km (2000 mi).
Important: This rate does not apply to vehicles that are driven in an aggressive manner, at high RPM, high speeds, or in a loaded condition (for trucks). Oil consumption for vehicles driven under these conditions will be more.
Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 11-17-2005, 07:18 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
Re: burning oil
yeah I was going to say the same thing, I noticed that too, but I just figured it was normal, mine is always low when I change it or check it after a while.
Old 11-17-2005, 07:53 PM
DonSor DonSor is offline
Re: burning oil
A quart every 3K miles is considered to be acceptable but I don't. Something is giving way in your cylinders but not enough to be concerned about. Most cars I've had mayl use about a pint or less every six thousand miles. Crankcase oil do not evaporate. You lose oild either thru leaks or burn. Cars with manual transmission tend to use a bit more oil because of the high cylinder vacuum during deceleration.
Old 11-17-2005, 10:21 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: burning oil
if your car makes blue smoke (which when burning that little oil probably doesn't happen) then you can determine the problem.....
1. If it burns oil on acceleration, you have bad piston rings and blowby gasses are burning the oil.
2. If it burns oil under heavy vaccuum (high rpm slowly decelerating) then the valve seats are bad....
of the 2 the valve seats are the easiest to fix, but they are by no means easy to fix if you don't know what you're doing.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-17-2005, 11:28 PM
Re: burning oil
Either way the head/s wll have to come off.
Old 11-18-2005, 12:50 AM
Schister66's Avatar
AF -Advisor
Re: burning oil
only if you're going to fix it......i would figure out whats wrong and personally i would just sell the damn thing instead of not having a car for a week or 2....My
Old 11-19-2005, 08:23 AM
victimizati0n victimizati0n is offline
Send a message via AIM to victimizati0n
Re: burning oil
when you fill up your car with oil, do you start it before you check it?
remember, the oil filter takes a hefty chunk out of there too.
My friend was pissed that his car was burning oil, and he found out that he wasnt checking the oil after he started it to see that he was low a half quart because of the filter.
Old 12-02-2005, 07:32 AM
hennigm4 hennigm4 is offline
Re: burning oil
Use mobile 1 to help stop engine wear from getting worse. I had a 3.4 that sounded like a diesel when it started, GM said it was piston slap which was normal. After I traded it in for my Impala the same GM guy said using mobile 1 will help prevent the premature engine wear. He said that is why vets come from the factory with it in it. I hope I dont get the piston slap or head gasket problems with my 3.8. I will change oil every 3k with mobile 1 and flush the coolant every year....Oh yeah the 3.4 head gasket blew 10k miles after I had the lower intake gaskets done...At least it made it to the dealer for a trade in....
Old 12-03-2005, 01:30 AM
bermis519 bermis519 is offline
Send a message via AIM to bermis519 Send a message via MSN to bermis519 Send a message via Yahoo to bermis519
Re: burning oil
My impala after every oil change was never a quart low, it was always full. A quart of oil in 3,000 miles is an awful lot to burn.
Old 12-07-2005, 08:04 AM
MCO_Death MCO_Death is offline
Send a message via AIM to MCO_Death Send a message via MSN to MCO_Death Send a message via Yahoo to MCO_Death
Re: Re: burning oil
My Impala has slow leaks at the oil-pan and intake and doesn't even burn a quart between oil changes (granted it gets changed every 2-3 weeks)
