Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 12-16-2007, 09:26 PM
f_champ2001 f_champ2001 is offline
97 Ford Exp
What would cause skipping and shaking on accelceration under normal conditions and no codes sent to computer? 5.4L with 133000M. Plugs and all
coil packs have been checked. Now with no code I am thinking EGR?
Any help? and thanks in advance
Old 12-17-2007, 01:04 AM
knelleken knelleken is offline
Re: 97 Ford Exp
some misfires will not throw a check engine light.
Old 12-28-2007, 05:40 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: 97 Ford Exp
A vac leak with the EGR valve will throw the CEL on too.........um..........02 Sensor?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 04-27-2008, 09:28 AM
riproaringca's Avatar
riproaringca riproaringca is offline
Re: 97 Ford Exp
You may want to check the rear differential as well. Mine was leaking last summer which created a shudder upon acceleration, so I had to:
  • clean the housing to remover grit, rust flaking, etc...
  • remove the cover
  • drain the lubricant
  • clean the cover thoroughly
  • apply a bead of gasket maker
  • reinstall the cover
  • refill with lubricant (and anti-slip additive, if you have that option on your truck)
Make sure that you use the proper gear oil - and gear oil additive if you have Trak-Lock, Posi-Trac or whatever Ford calls their anti-slip gear.
The refill hole is on top of the differential housing. It's hard to see while you're under the vehicle, but there's a retaining bolt holding the "plug" in place. It will likely have a bunch of dirt on top of it as well. Take your time to clean it well before opening it up.
It's an easy fix. Just take your time to make sure the housing is clean before you remove the cover so that there isn't a bunch of grit getting into the works.
I repainted my housing cover before putting it back on, too. Helps avoid further corrosion.
[email protected]
Peterborough, Ontario
1995 Escort LX 3DR - 1.9L, 4cyl. w/ OD
1997 Sable GS Wagon - 3.0L, 6cyl. w/OD
1997 Expedition XLT - 5.4L, 8cyl. 4x4 w/OD
1999 Escort ZX2 Coupe - 2.0L 4cyl. w/OD
1999 Taurus SHO - 3.4L 8cyl. w/OD
2002 F150 4x2 SuperCab XLT - 4.6L 8cyl w/OD
