Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 12-05-2005, 04:13 PM
iponnet iponnet is offline
where is my evap canister!
I have a 2000 crown vic and just cant seem to find my charcol canister my check engine light was on and after I ran the scanner I got code P0443 evap emission control system, purge valve c fault, I guess my purge valve is malfunctioning but I cant find my canister to find the dam purge valve! any help appreciated
Old 12-05-2005, 05:26 PM
reekor reekor is offline
Re: where is my evap canister!
My 89, 92, 94 has the dam charcol canister mounted on the right hand side between the rad support and the dam bumper rebar, you can only see it if you look from under the dam car. The dam purge valve is mounted on the inner fender near the dam battery.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 12-05-2005, 07:46 PM
BMFer1's Avatar
BMFer1 BMFer1 is offline
As of the 1998 model year, Ford began mounting the canister & purge valve on the bottom side of the trunk.
BMFer1
Old 12-05-2005, 07:49 PM
thanks for the replies guys found it,,
Old 12-06-2005, 06:46 AM
fleettech fleettech is offline
I just had that code on a pd car and it turned out to be a broken wire about an inch behind the evap purge solonoid up on the fire wall. pull the loom back a little and it was right under where it was factory taped. it was broken inside the insulation so you might have to undo the ecm connector and ohm out the wire I think it was pin 65 and the green wire/black tracer on the solonoid plug.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
