Go Back   Automotive Forums .com Car Chat > Pontiac > Montana/Montana SV6
Old 12-07-2005, 02:23 PM   #1
99999
2000 pontiac montanna antifreeze leak
I have a leak in my pontiac montana 2000 antifreeze leak. My question is how can i tell if its my intake gasket or its my head gasket? If anyone can help me i would appriciate it thanks.
99999 is offline   Reply With Quote
Old 12-07-2005, 02:52 PM   #2
cdru
cdru's Avatar
Re: 2000 pontiac montanna antifreeze leak
Tracer dye would indicate where the leak was if it was external. The presence of antifreeze in the oil usually is the intake, and not the head, gasket. No antifreeze leaking externally, the loss of coolant somewhere, and no coolant in the oil would indicate possible a possible head gasket leak into the cylinder.
Vinyl adds horsepower, right?
cdru is offline   Reply With Quote
Old 12-07-2005, 03:19 PM   #3
Chameleon-kat
Chameleon-kat's Avatar
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
Re: Re: 2000 pontiac montanna antifreeze leak
If its the intake gasket you may be able to see external leak. I have a couple pics of what it might look like in this topic:
http://www.automotiveforums.com/vbul...d.php?t=476571
Chameleon-kat is offline   Reply With Quote
Old 12-08-2005, 04:16 AM   #4
99999
Re: Re: Re: 2000 pontiac montanna antifreeze leak
[quote=Chameleon-kat]If its the intake gasket you may be able to see external leak. I have a couple pics of what it might look like in this topic:
http://www.automotiveforums.com/vbul...d.php?t=476571[/QUOTE Thanks because i went to three garages and two of them told me it was my head gasket and one told me it was my intake gasket "confused" i dont want to replace the intake gasket and than they tell me no it was ur head gasket or vice versa. I checked my oil it looks fine and checked for any gunk did not find any, no signs of where the coolant is going none in my drive way.
Old 12-08-2005, 08:15 AM   #5
cdru
cdru's Avatar
If it is a small leak and only leaks under pressure (engine hot), then you may never see a drip on the ground until it worsens considerably. If it's leaking similar to where the pictures were leaking, it would run down the hot engine block and evaporate before it reached the ground.
