Go Back   Automotive Forums Car Chat > Eagle > Vision
Old 09-10-2006, 02:19 PM
filly filly is offline
1994 Vision TSI
I have a overheating promblem. I have removed the t-stat, flushed and reversed flushed the motor, heater core , radiator, replaced the water pump. If I drive about 12 miles it just overheats. The rest of the time to temp is fine. This happens either driving it hard or taking it easy. Thank.
Old 09-11-2006, 10:40 AM
Knifeblade Knifeblade is offline
Re: 1994 Vision TSI
Hard to tell.
Is the coolant adequate and 50/50 mix? Is there a leak that loses coolant, e.g. a hose or fitting? Does the cooling fan turn on?
Old 09-11-2006, 11:56 AM
Re: 1994 Vision TSI
Fan turns on I notices a little white smoke coming out the exhaust. So either bad head,or gasket or really bad cracked block.
Old 09-11-2006, 11:08 PM
Re: 1994 Vision TSI
Run a Compression test on the cylinders. Any leakdown points to what you may already have thought. Ouchers.
Old 03-13-2007, 09:01 PM
mike1965 mike1965 is offline
Re: 1994 Vision TSI
change coolant temperature sensor/right next to t/stat
