Go Back   Automotive Forums .com Car Chat > Pontiac > Trans Sport
Old 11-19-2005, 04:11 PM   #1
Icarus3000
95 Transport - Washer Fluid Pump
The front washer fluid pump seems to have burnt out on me. Rear works fine. When I press on "wash" for the front, the wipers move, but no fluid comes out, and the pump doesn't make any sound.
Question:
Is there a separate fuse for the front wash pump?
If not, then I think I need a new wash pump.
Does anyone know the part number for the pump? It looks like it would be easy to replace - anyone have an opinion on this, I know sometimes looks can be deceiving...
Thanks!
Icarus3000 is offline   Reply With Quote
Old 11-19-2005, 04:48 PM   #2
nicke66
Testing- Washer Fluid Pump
Exchange the connectors for the pumps. If you then get water on the front, when flushing the back, you know the pump is defective.
nicke66 is offline   Reply With Quote
Old 11-20-2005, 12:06 AM   #3
LMP
LMP's Avatar
Re: 95 Transport - Washer Fluid Pump
I'd like that too....Problem is the 2 plugs are dissimilar and will not connect to wrong pump..so a pair a small wires can be used to feed 12v direct to pump for a test.
Pump can suffer from "wiper syndrome"..related to faulty printed circuit board part of wiper motor...
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
LMP is offline   Reply With Quote
Old 11-20-2005, 02:43 PM   #4
Icarus3000
Re: Re: 95 Transport - Washer Fluid Pump
To feed 12v direct to pump for a test, do you mean direct from the battery + to one side, and battery - to the other?
I hope it isn't the circuity board, I just changed it last year and it was a major pain in the @$$!
Thanks!
Old 11-20-2005, 04:54 PM   #5
LMP
LMP's Avatar
Indeed, 12v from the battery supply to the pump motor. Direction of rotation changes with change of polarity. If board new, I'd bet for the pump.
Old 11-22-2005, 11:52 AM   #6
zephram22
zephram22's Avatar
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
Question:
Thanks!
There may be a fuse, but either way, you should be able to go to the junkyard and get a pump for five dollars. You could also try cleaning the elctrical connections to the pump.
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
zephram22 is offline   Reply With Quote
Old 11-23-2005, 10:08 AM   #7
timguyli
I have many of these for sale. $6.00 and that includes shipping!
timguyli is offline   Reply With Quote
