Go Back   Automotive Forums .com Car Chat > Buick > Regal
Old 11-09-2005, 06:49 PM   #1
Chis123
Regal GS tires
Recently purchased Buick Regal GS 2000. Very happy with vehicle. Just bought rims and tires for the winter but I will be looking for some summer tires very soon. The summer tires (225-60-16) are mounted on the original mags, but are worn out. Can I fit a wider tire ie.50 series on these mags and can anyone suggest good tires? Thanks
Chis123 is offline   Reply With Quote
Old 11-09-2005, 07:36 PM   #2
HotZ28
AF Moderator Elite
HotZ28's Avatar
Re: Regal GS tires
Actually, the 50 series is shorter than the 60 series not wider. If you want to try a wider tire, go with the 245-50-16. (shorter & wider) Try one first on the front and see if it will turn side to side without hitting the fenderwell. The back should clear.
Knowledge can be communicated, but not wisdom!
HotZ28 is offline   Reply With Quote
Old 11-20-2005, 07:56 PM   #3
Big Dan58
Send a message via Yahoo to Big Dan58
Hot Z28 is right. The 50 or 60 means the percentage of the width of the tire. A 50 series has 50% of the tires width as the height, etc. I bought a regal GS for my kid. Real nice ride, but the rims are only 6” wide so it limits the size of the tire that will fit. Not sure if you can go as wide as a 245 60/16. It may not fit the rim and if it does, the high offset of the wheel may cause it to rub on the inside fender wells when making turns.
Big Dan58
Panic, Chaos and Confusion... My work here is done!
Big Dan58 is offline   Reply With Quote
Old 11-21-2005, 08:10 AM   #4
BNaylor
BNaylor's Avatar
Re: Regal GS tires
I agree the stock 16" wheel which is 6.5" in width does not have the proper offset to run 245 tires and may rub. The other problem with running a lower aspect ratio such as 50 series is you will have speedometer error unless you go to 17 inch wheels to compensate. When speedo reads 65 mph, it will actually be going around 62.6 mph. The diameter should be matched as close as possible to what stock (225/60-16) has, I believe around 26.63".
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
