1996 Plymouth Grand Caravan SE. passenger window help?
Hello
My first thread and a hello to all. I was at the beach on Saturday and my passenger POWER window was down, when I went to put it up there was no response. There is no response from the driver sidedoor and the passenger side door. What do I do to fix this. I dont believe there is a fuse.. please help and thanks in advance. there is a cold beer in it for you! Scott |
![]() Join Date: Apr 2005
Re: 1996 Plymouth Grand Caravan SE. passenger window help?
If I remember correctly, there is a circuit breaker for the power windows. When you remove the fuse box cover look inside the cover, you should see all the fuses and breakers clearly marked.
#3 | ||
Re: Re: 1996 Plymouth Grand Caravan SE. passenger window help?
Scott |
Re: Re: Re: 1996 Plymouth Grand Caravan SE. passenger window help?
Check the owner’s manual. It is also possible that you a have resetting fuse for the power windows, if that’s the case your BCM has to be reset with a scanning tool. Good luck.
#5 | ||
Re: Re: Re: Re: 1996 Plymouth Grand Caravan SE. passenger window help?
Re: Re: Re: Re: Re: 1996 Plymouth Grand Caravan SE. passenger window help?
If the manual doesn’t specify resetting fuse for the power window, then you have a circuit breaker in the fuse box, but I don’t know which breaker is for the power window.
#7 | ||
![]() Join Date: Nov 2005
Re: Re: Re: Re: Re: Re: 1996 Plymouth Grand Caravan SE. passenger window help?
Hey my sister inlaws caravan does the same but if U push the window up or down if works for a bit have oiled the cables and springs the only thing that I can think of is that the regulator springs have gotten weak cause if I pull the cable off the spring it works. dealer said needs new regulater assc. springs Not Avail. try Junk Yard if pushing or pulling on the window works |
#8 | ||
Re: Re: Re: Re: Re: Re: Re: 1996 Plymouth Grand Caravan SE. passenger window help?
I should of been more consice there are 2 limiting switches on the regulator and motor assc. that have springs on them that activate when the cable is pulled taunt shutting off the motor pushing up and down puts the window in motion . also check for power @ the switch and motor may be a loose connection but if the drivers side works I dout its a fuse or relay |
