Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 10-08-2005, 11:21 AM
Jetta545 Jetta545 is offline
Question Engine Light
I have 96 Jetta 2.0 . I am having a problem with my engine light coming on and motor no starting in damp and rainy weather. I got the codes read at auto zone Code numbers P0440 Malfunction in Evaportive Emissions, And code p1580 Electronic Throttle Monitor PCm Override ????
If it does not rain out for a couple of weeks the light will turn off Car runs fine. What can this Be???
Old 10-08-2005, 03:13 PM
boschmann boschmann is offline
Re: Engine Light
I don't think it would be related to the EVAP code, but could be from the throtlle valve code. Make sure it isn't an ignition coil problem - spray water on the coil only & see if it has the same problem. Otherwise unplug the throttle valve electrical connector & clean the contacts. It may be difficult to restart after unplugging. Unfortunately, failure of the unit is common.
Old 10-08-2005, 09:37 PM
Re: Engine Light
I will give it a shot I will let you know what happens Thanks
Old 10-12-2005, 07:00 PM
Re: Engine Light
I checked all connectors they look like new. I sprayed the coil and nothing. I hit the wires by the ditributer cap and the car shot right down and whould not start until the next day. Could it be the wires?
Old 10-12-2005, 09:18 PM
Re: Engine Light
Yes, pull the wires & look for corroded ends, cracks in the cap, etc....
Old 10-14-2005, 07:44 PM
Re: Engine Light
I can't find any cracks but I will try to change the wires and cap because it has the factory ones. What is the best ones to get for this car?
Old 10-22-2005, 12:43 PM
Re: Engine Light
Uh... Bosch
Old 11-14-2005, 05:36 PM
jett-n-along jett-n-along is offline
Re: Re: Engine Light
Hi,
I have the same problem..I was looking for the outcome to this thread...I had a feeling it could be the cap and rotor..Im wondering if he replaced the rotor too......I also have a code that came up at the same time P1613.. sbds interactive codes..Thanks in advance for any input AJ
Old 11-14-2005, 06:00 PM
Re: Re: Re: Engine Light
OK a i found the thread with this code....it seems that the code p1613 comes up together w/p1580...even tho p1613 is bad communication with the computer..Im willing to bet that both codes clear when the ignition problem is fixed....
My car continues to run after its warmed up and starts when its warm..It did not rain today...i did have a problem with it losing power a couple times..Im thinking that it could be the cat..moreso then the ignition coil...however it does start then dies as long as my foot is off the gas..as soon as i take my foot off the gas it stalls till its warmed up..What ya'll think??
