i have a friend with a 95 neon and the tranny all of a sudden decided it wasn't go to go anywhere. When you put it in drive it catches the gear very little you have to floor it literally for it to start to go, but the reverse gear works perfectly fine. Any ideas and suggestions would be greatly appreciated. Thanx.
Tuning Neons since '97
A few things to check would be the throttle linkage, fluid level, and the kickdown band may need to be adjusted.
#3 | ||
Re: transmission
how would i adjust the kickdown band because the throttle linkage and fluid level are fine. |
#4 | ||
Re: Re: transmission
http://www.automotiveforums.com/vbul...=kickdown+band Do you know what type of fluid is in the tranny and is it an ATX or MTX? |
#5 | ||
Re: Re: Re: transmission
#6 | ||
Re: Re: Re: Re: transmission
#7 | |
they told me it might be the torque converter, how would i find out before i rip apart the trans to change it for nothing and also before i spend the money to do it to.
#8 | ||
Re: Re: Re: Re: Re: Re: transmission
#9 | ||
Re: Re: Re: Re: Re: Re: Re: transmission
#10 | |
Re: transmission
try putting it in manual low and take off. If it takes off much better than in drive low, than you have a bad overrunning clutch, which means, tranny rebuild. I would also suggest getting your pressures looked at, sounds like the rear clutch, which engages in all forward gears is starting to slip.
Daily Overhauls Do Get Expensive Dangerous On Days Gears Engage Dead On Day Guarantee Expires Dead Or Dying Gas Eater Department Of Defense Garbage Equipment Dodge Owners Don't Get Excited Don't Overdrive Gutless Engine Drips Oil Drops Grease Everywhere 1995 Dodge Dakota SLT 3.9 V6 1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4 |
#11 | ||
#12 | |
Re: transmission
thanks everyone i'll give it a try a see what happens before i buy another trans.
