Old 11-18-2005, 06:35 PM
mike1224's Avatar
mike1224 mike1224 is offline
Send a message via AIM to mike1224 Send a message via MSN to mike1224 Send a message via Yahoo to mike1224
resizing pictures from dig. camera
I am wondering how i can change the resolution on some photos of my truck from 640X480 to 100X100 to create a GIF file for my Avatar.
2002 Chevy S-10 ZR2
Originally Posted by balls_to_the_wall
Some people are alive only because its illegal to kill them.
Old 11-18-2005, 06:54 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
Re: resizing pictures from dig. camera
if you have photoshop, take the pic and press "alt" "i" "s" (can't remeber the actual menus, i go by the shortcuts)
then make both height an width the same number of pixels.
once that's done press "alt" "i" "i" and type 100 in both boxes, that'll make it the 100x100 size.
if i've confused you, you can send me the pic an i'll do it for you, no worries.
Seatbelts Saved My Life
dimefury's Avatar
dimefury dimefury is offline
my computer came with a cheap paint program
it can resize and change pic file format
if you have a dell, you probably have this program
go to the start button in the low-left corner
click on all programs
look for a folder labeled accessories
pick the paint program
to resize with this program
click on image
click on stretch/skew
to change to a different file type
click on file
click on save as....
at the bottom it will ask you to chose file type
hope that helped some
Old 11-18-2005, 07:34 PM
mike1224's Avatar
i found a program called AutoImager. It changed the pixel ratio. I appreciate everyone's help.
2002 Chevy S-10 ZR2
Old 11-18-2005, 10:36 PM
julirog julirog is offline
I have a variety of graphic programs and most of them will allow you to resize a picture without changing the resolution. And...increasing the resolution will not normally give you a better picture -- just more dots.
To find the "resize" option, either use their help index...or go through the commands under FILE, EDIT, VIEW, IMAGE, etc.. Resize (if it is supported by your program) is sometimes in the drop-down menus under IMAGE/TRANSFORM or EDIT/RESIZE.
Post the program that you are using, and perhaps someone also has it so that they can be more specific.
Old 11-18-2005, 10:59 PM
mike1224's Avatar
Re: Re: resizing pictures from dig. camera
2002 Chevy S-10 ZR2
